Can anyone recommend a good quality engine assembly lube and a decent sealant for the crankcase halves ?
Cheers, Steve
Recommendations
- wheelysteve
Recommendations
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: Recommendations
As advised by Al, Loctite 5980 is good but always buy it from a shop as it has a Use By date and will not go off if it's exceeded - the date is on the tube, not the box. You can get it from Halfords.
Re: Recommendations
I use these.
The Vtech is good for all the case joints, Cam end plugs , Alternator grommet etc.
https://www.ebay.co.uk/itm/VT-157-Quali ... zyLv1Sv3C1
And the Graphogen for the cam shells, buckets, Piston skirts etc etc.
https://www.ebay.co.uk/itm/Engine-Build ... SwleNcph0g
- wheelysteve
Re: Recommendations
Thanks lads.
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
LTD Project
Re: Recommendations
For engine assembly I use 50/50 molybdenum grease and engine oil.
Otherwise Blue Hylomar or Loctite for joint faces.
Good Luck!
Good Luck!
KZ1000 B4 under light restoration.
