Hi all ,
I'm looking to fit some non pumped z1000 carbs to my z650
Is it worth doing? A straight forward job and any ideas on jetting
If fitted...
Cheers Dave
Z650 (z1000 carbs)
Re: Z650 (z1000 carbs)
It's a common mod and will wake up the motor a bit.
You need to use the 900/1000 inlet rubbers too and slot the mounting holes slightly to get them to fit as the holes are fractionally wider apart than the 650.
Start with the stock 1000 jetting and work down on the mains.
Sure Padders has a set for sale
