I've finally got round to draining the oil from my Z900 and exhaust pipe No3 appears to run very close to the oil filter cover plate - does this come off without being obstructed by the pipe or do I need to drop/swing the pipe out of the way?
I'm asking as I don't want to find out once I've dropped the cover plate.
Cheers, Andrew
Oil filter cover plate, obstructed by No3 exhaust?
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
- wheelysteve
Re: Oil filter cover plate, obstructed by No3 exhaust?
You should have enough wiggle room once you lower the filter. `I didn't take my exhaust off to change it.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
wheelysteve wrote:You should have enough wiggle room once you lower the filter. `I didn't take my exhaust off to change it.
Thanks Steve.
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Ended up having to loosen exhaust No 3 & 4 to gain a few mm to refit the oil filter cover plate - no big deal and job now done!
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Can't you just remove bolt completely, then the filter plate should move away from pipe slightly?
Pigford wrote:Can't you just remove bolt completely, then the filter plate should move away from pipe slightly?
Yeah, I did that to remove it and just pulled the bolt out but refitting it wasn't that straight forward as the I'd fitted the filter, spring and washer onto the plate and the bolt would not line up (didn't want to bugger the thread) so just loosened up the exhausts to gain some movement and it popped straight in - just took an extra 10 mins.
Current Bikes:
2023 R1250 GSA
2023 R1250 GSA
Andrew_s wrote:Pigford wrote:Can't you just remove bolt completely, then the filter plate should move away from pipe slightly?
Ahhh, forgot about re-fitting! At least it wasn't too difficult fitting the bit's bit loosening pipes
