Oil filter cover plate, obstructed by No3 exhaust?
Andrew_s
#1 PostAuthor: Andrew_s » Mon May 04, 2020 12:13 pm
I've finally got round to draining the oil from my Z900 and exhaust pipe No3 appears to run very close to the oil filter cover plate - does this come off without being obstructed by the pipe or do I need to drop/swing the pipe out of the way?
I'm asking as I don't want to find out once I've dropped the cover plate.
Cheers, Andrew
Current Bikes:
2023 R1250 GSA
wheelysteve
Re: Oil filter cover plate, obstructed by No3 exhaust?
#2 PostAuthor: wheelysteve » Mon May 04, 2020 12:22 pm
You should have enough wiggle room once you lower the filter. `I didn't take my exhaust off to change it.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Andrew_s
#3 PostAuthor: Andrew_s » Mon May 04, 2020 12:31 pm
wheelysteve wrote:You should have enough wiggle room once you lower the filter. `I didn't take my exhaust off to change it.
Thanks Steve.
Current Bikes:
2023 R1250 GSA
Andrew_s
#4 PostAuthor: Andrew_s » Mon May 04, 2020 3:48 pm
Ended up having to loosen exhaust No 3 & 4 to gain a few mm to refit the oil filter cover plate - no big deal and job now done!
Current Bikes:
2023 R1250 GSA
#5 PostAuthor: Pigford » Mon May 04, 2020 5:28 pm
Can't you just remove bolt completely, then the filter plate should move away from pipe slightly?
Andrew_s
#6 PostAuthor: Andrew_s » Mon May 04, 2020 6:49 pm
Pigford wrote:Can't you just remove bolt completely, then the filter plate should move away from pipe slightly?
Yeah, I did that to remove it and just pulled the bolt out but refitting it wasn't that straight forward as the I'd fitted the filter, spring and washer onto the plate and the bolt would not line up (didn't want to bugger the thread) so just loosened up the exhausts to gain some movement and it popped straight in - just took an extra 10 mins.
Current Bikes:
2023 R1250 GSA
#7 PostAuthor: Pigford » Tue May 05, 2020 11:14 am
Ahhh, forgot about re-fitting! At least it wasn't too difficult fitting the bit's bit loosening pipes :up
