Air Corrector Jets for 24,26 and 28mm Mikunis.Z650,Z1,Z9,Z1000.Also Suzuki GS 750,850,1000. £32 posted.
Advertise your BIKES and PARTS here
Re: Z650,Z1,Z9,Z1000.AIR CORRECTOR JETS. Last few sets.. Price drop...
#46 PostAuthor: zed1015 » Tue Oct 29, 2019 8:17 pm
rangeroy wrote:if you have a set left pm me & I will paypal you to your details ,I'm sure my old z650 will be greatful.
regards theranger
PM sent.
Re: Air Corrector Jets for 24,26 and 28mm Mikunis.Z650,Z1,Z9,Z1000.Also Suzuki GS 750,850,1000. £32 posted.
#47 PostAuthor: zed1015 » Sun Dec 29, 2019 7:59 pm
Still available.
#48 PostAuthor: zed1015 » Wed May 20, 2020 9:14 am
A little update also added to the original 1st post..
Jets also available for CV carbs on KAWASAKI ZR550A1, Z650, Z750L3. ,GT750, GPZ750,Z750 CUSTOM. Z1000J1/J2/J3/R, Z1100A1/A2/A3 - SUZUKI GS550 mx/mz Katana. GS650GT, 650 Katana 81, GSX750ET, GS850G, GS1000E/G, GS1100G, GSX1100 early, GSX1100G/KATANA and Kawasaki ZR550A1, Z650, Z750L3. ,GT750, GPZ750,Z750 CUSTOM.Z1000J1/J2/J3/R, Z1100A1/A2/A3 and YAMAHA XS1100 78-81, XJ900 83.
Robw
#49 PostAuthor: Robw » Wed May 20, 2020 10:14 am
Hi, could i have a set please for set of 34 CV carbs on a gpz 1100b1?
Cheers Rob
#50 PostAuthor: zed1015 » Wed May 20, 2020 10:38 am
Robw wrote:Hi, could i have a set please for set of 34 CV carbs on a gpz 1100b1?
Cheers Rob
Sent you a PM.
rickm
#51 PostAuthor: rickm » Wed May 20, 2020 1:45 pm
What actually comes with the CV carb kit ? i.e. jets, etc.
H2B GPZ900R
#52 PostAuthor: zed1015 » Wed May 20, 2020 3:20 pm
rickm wrote:What actually comes with the CV carb kit ? i.e. jets, etc.
Hi, Rick.
Just the 4 corrector jets and I can supply info for the recommended main jetting if needed .
#53 PostAuthor: zed1015 » Tue May 04, 2021 12:42 pm
Update...
Due to lack of demand i've discontinued making the jets for CV carbs .
Jets for the VM24,26 and 28's will remain available.
Gus
#54 PostAuthor: Gus » Tue May 04, 2021 12:55 pm
zed1015 wrote:Update...
Sorry if I missed something.
Was there a difference between the VM and CV jets?
Confused Gus
"Set the GRINDER on it"
#55 PostAuthor: zed1015 » Tue May 04, 2021 1:21 pm
Confused Gus
Yes! There differences in orifice sizes depending on model.
Hardly sold any CV ones so not worth the layout for the different micro jet drills which are not cheap and break regularly.
VM ones are popular so manage to cover costs with those.
Gus
#56 PostAuthor: Gus » Tue May 04, 2021 2:09 pm
Ahh the penny has dropped.
Cheers for the explanation
Gus
tim.25
#57 PostAuthor: tim.25 » Sun Jul 18, 2021 6:36 pm
Many thanks Rob worked a treat , no flat spots at all.
Running 1015 with Vm26s and bellmouths, perfect.
Z900a4, BMW 1200GS, H-D 1200, KTBFFH
#58 PostAuthor: zed1015 » Wed Jun 01, 2022 10:50 am
A reminder ( also added to amended first post) to be aware of that some KAWASAKI VM26SS carb sets that are only equipped with the FUEL mixture screws underneath are made up of all left or right handed carb bodies..
In this instance the jets must be installed in the air passage furthest away from the unmachined air screw boss.
In the case of left hand bodies ALL the jets should be fitted at the 4 o'clock position and on right handed bodies all at 8 o'clock..
See attached pic for example of a left hand body set with the jets installed in the 4 o'clock position..
Also available again for CV carbs on KAWASAKI ZR550A1, Z650, Z750L3. ,GT750, GPZ750,Z750 CUSTOM. Z1000J1/J2/J3/R, Z1100A1/A2/A3 - SUZUKI GS550 mx/mz Katana. GS650GT, 650 Katana 81, GSX750ET, GS850G, GS1000E/G, GS1100G, GSX1100 early and GSX1100G/KATANA.
These too require the jets to be installed in the 4 o'clock position on all CV bodies as they are not handed.
Zebedee
#59 PostAuthor: Zebedee » Wed Jun 01, 2022 11:34 am
Rob is it too late to include a set for me?
Zedbedee Zz
Big Zed medium zed and little zed
Z1000 LTD Z900 ltd z650 B1
:oops:
I’m normally doing something.
Quite often its something wrong?
Its just I don’t realise until later.
#60 PostAuthor: zed1015 » Wed Jun 01, 2022 12:50 pm
Zebedee wrote:Rob is it too late to include a set for me?
PM sent.
Return to “For Sale”
