projector tip plugs.
Has anyone on here used projector tip plugs in their Zeds and what would any upsides be, i ask as someone said they use bp8es in their Zed, i know the tip is around 1.5mmlonger than b8es, just curious as to why.
- warren3200gt
Re: projector tip plugs.
Hi Kev, another forum member drop there 650 off to me for some work. It had projector 8,s in and ran ok. Ran a lot better with denso 22's. There was no clearance issues and no apparent benefits.
warren3200gt wrote:Hi Kev, another forum member drop there 650 off to me for some work. It had projector 8,s in and ran ok. Ran a lot better with denso 22's. There was no clearance issues and no apparent benefits.
Denso Iridium are very good - ran the same set in my olds Z1000 (1075) for a few years, did many thousand miles of long/shorts trips plus a bit of sprinting; used to rag it and the plugs were trouble free.
You'd be better off indexing and possibly side gapping the stock plugs if you want to get the best out of them.
I don't have any running problems using stock b8es and not changing them either, just asking out of curiosity in relation to others use of projector tip plugs.
Users browsing this forum: tightwad and 62 guests
