Ex drag bike back on the road
Re: Ex drag bike back on the road
#31 PostAuthor: Pigford » Mon Aug 10, 2020 6:00 am
That's sweet :up
thebuelligan
#32 PostAuthor: thebuelligan » Mon Aug 10, 2020 1:38 pm
Pigford wrote:That's sweet :up
Thanks Its getting there slowly!
thebuelligan
#33 PostAuthor: thebuelligan » Wed Aug 12, 2020 8:57 pm
AP master cylinder all done.. stripped, powder coated, new piston, and seals.
thebuelligan
#34 PostAuthor: thebuelligan » Thu Aug 20, 2020 10:14 pm
Rear frame crossmember was missing so made one up today
Paulb
#35 PostAuthor: Paulb » Sat Aug 22, 2020 10:11 am
WOW!! That looks stunning. Keep us posted
Z900A4.
Ducati Streetfighter V4 S
#36 PostAuthor: chrisNI » Sat Aug 22, 2020 11:19 am
Nice work! :D
thebuelligan
#37 PostAuthor: thebuelligan » Sat Aug 22, 2020 8:28 pm
Realised that I needed an addition to the crossmember today to support the rear seat damper
ollie
#38 PostAuthor: ollie » Sat Aug 22, 2020 11:13 pm
nice work ,its coming together :up :clap
thebuelligan
#39 PostAuthor: thebuelligan » Sun Aug 23, 2020 6:33 pm
Couple of hours fiddling on some smaller bits and pieces today! Sorted out the boost gauge bracket .. not sure where I’m going to eventually mount it as yet!!
Also thinking of using the original switch gear block to mount some micro gadget switches as the starter button etc were missing!
thebuelligan
#40 PostAuthor: thebuelligan » Tue Aug 25, 2020 6:55 pm
Russ Collins plenum inlet
thebuelligan
#41 PostAuthor: thebuelligan » Fri Sep 04, 2020 8:49 pm
Another small job done this evening
Had welded on a bracket on the frame for the seat Latch and wanted a simplified version mainly because of been lazy and not wanting to fab all the brackets etc for locks an levers etc!
Been putting off sorting this for a while so decided just to get on with it and make it up as I went along .. Came out ok and importantly it works
thebuelligan
#42 PostAuthor: thebuelligan » Fri Sep 04, 2020 8:51 pm
More seat latch
thebuelligan
#43 PostAuthor: thebuelligan » Fri Sep 04, 2020 8:52 pm
Lat ones
#44 PostAuthor: chrisNI » Fri Sep 04, 2020 10:22 pm
This is a great bit of work :D
thebuelligan
#45 PostAuthor: thebuelligan » Sat Sep 26, 2020 2:31 pm
Fork tubes back from Hard Chroming Mansfield so rebuilding commences!!
Rechromed rather than new as the tubes are 65mm shorter than standard which is perfect as I was going to shorten by 2 to 2 1/2 inches
These tubes came with some early forks I bought .. cut springs but short tubes Really interested to know what they came from if any members can shed light!! :D
