Ex drag bike back on the road
- thebuelligan
Re: Ex drag bike back on the road
Pigford wrote:That's sweet
Thanks Its getting there slowly!
- thebuelligan
AP master cylinder all done.. stripped, powder coated, new piston, and seals.
- Attachments
- B278D525-C42E-4DCC-AADF-781DE990D898.jpeg (155.42 KiB) Viewed 257106 times
- 05DB2A92-6CAE-4750-8912-8EA36480BC33.jpeg (122.02 KiB) Viewed 257106 times
- E517ED40-7930-4C97-BBA4-B81D17285A51.jpeg (141.03 KiB) Viewed 257106 times
- 7A07AD0C-DECF-4349-9D3D-514D532F36CB.jpeg (142.05 KiB) Viewed 257106 times
- 8C9C8AF7-DB90-41AD-BA8A-F11A6096612C.jpeg (121.1 KiB) Viewed 257106 times
- thebuelligan
Rear frame crossmember was missing so made one up today
WOW!! That looks stunning. Keep us posted
Z900A4.
Ducati Streetfighter V4 S
Nice work!
- thebuelligan
Realised that I needed an addition to the crossmember today to support the rear seat damper
- Attachments
- E3582556-CBC0-41F5-81CE-EA6952E94631.jpeg (109.83 KiB) Viewed 256968 times
- C2A360CA-C568-4509-870C-02E22DD0A3A7.jpeg (99.32 KiB) Viewed 256968 times
nice work ,its coming together
- thebuelligan
Couple of hours fiddling on some smaller bits and pieces today! Sorted out the boost gauge bracket .. not sure where I’m going to eventually mount it as yet!!
Also thinking of using the original switch gear block to mount some micro gadget switches as the starter button etc were missing!
- thebuelligan
Russ Collins plenum inlet
- Attachments
- F28163A7-BE1E-4D64-A06C-A9CA17832216.jpeg (38.38 KiB) Viewed 256891 times
- 772A67BD-C49F-4F16-94C8-7B2F7AD64949.jpeg (39.29 KiB) Viewed 256891 times
- thebuelligan
Another small job done this evening
Had welded on a bracket on the frame for the seat Latch and wanted a simplified version mainly because of been lazy and not wanting to fab all the brackets etc for locks an levers etc!
Been putting off sorting this for a while so decided just to get on with it and make it up as I went along .. Came out ok and importantly it works
- Attachments
- 24BE3F82-A059-48E5-8FDE-BCCFA5F1B95D.jpeg (80.85 KiB) Viewed 256842 times
- 94C2A8AF-0545-4791-A3E2-2168836DA97E.jpeg (117.71 KiB) Viewed 256842 times
- 4EBF5737-A030-44D9-B001-B216F94510FB.jpeg (133.24 KiB) Viewed 256842 times
- 3C458AA4-FB3F-4970-AD90-7E8D765908A0.jpeg (107.46 KiB) Viewed 256842 times
- thebuelligan
More seat latch
- Attachments
- E909FA37-C66D-442C-A692-7C9032B62360.jpeg (125.46 KiB) Viewed 256843 times
- D0CE32FC-13E8-4716-998E-D5E2C74CFCD4.jpeg (127.96 KiB) Viewed 256843 times
- 32ECC7C6-F0EB-4A33-8CBF-4F089BC9E225.jpeg (125.47 KiB) Viewed 256843 times
- 708CF67F-56E7-4CA4-AEC8-52234F6B2E22.jpeg (125.35 KiB) Viewed 256843 times
- 74294FB5-5422-4BA0-87E3-4C4F6EDDEB55.jpeg (143.27 KiB) Viewed 256843 times
- thebuelligan
Lat ones
- Attachments
- 83B6204B-440F-42A5-A227-86AE9310B84D.jpeg (80.51 KiB) Viewed 256844 times
- 5499401E-B670-41A4-B0BA-CE6A3B2BA676.jpeg (92.81 KiB) Viewed 256844 times
- 67615265-A59A-4F31-B30D-7D287D3E6EA5.jpeg (93.18 KiB) Viewed 256844 times
- 4B5B0919-F194-44BA-B313-382F878B112B.jpeg (98.42 KiB) Viewed 256844 times
This is a great bit of work
- thebuelligan
Fork tubes back from Hard Chroming Mansfield so rebuilding commences!!
Rechromed rather than new as the tubes are 65mm shorter than standard which is perfect as I was going to shorten by 2 to 2 1/2 inches
These tubes came with some early forks I bought .. cut springs but short tubes Really interested to know what they came from if any members can shed light!!
