Auxiliary fuel feed
steve452
Auxiliary fuel feed
#1 PostAuthor: steve452 » Mon Oct 19, 2020 12:59 pm
I'm about to fire up my Z1-B for the first time in 43 years. I've bought a Sealey overhead 1ltr fuel feed but it only has a single pipe and tap spigot. Is there a preference for which fuel pipe I connect it to, and should the other pipe be plugged or left open to atmosphere?
Z1-B, 360bhp ZX1000NGF
wheelysteve
Re: Auxiliary fuel feed
#2 PostAuthor: wheelysteve » Mon Oct 19, 2020 1:00 pm
Use a t piece to feed both carbs
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
steve452
#3 PostAuthor: steve452 » Mon Oct 19, 2020 1:04 pm
What happens if you don't have a T-piece?
#4 PostAuthor: zed1015 » Mon Oct 19, 2020 1:25 pm
steve452 wrote:What happens if you don't have a T-piece?
You will only get fuel to two cylinders
#5 PostAuthor: z1bman » Mon Oct 19, 2020 2:51 pm
steve452
#6 PostAuthor: steve452 » Mon Oct 19, 2020 3:52 pm
Thanks Rob. I actually stripped down a spare fuel tap to see how it worked and came to the same conclusion :D However at the moment that is academic as I connected up my tank to the fuel line for carbs #1 & 2 to check all was OK and heard a strange dripping noise. No prizes for guessing that the noise was the fuel pissing out of the two overflow hoses. Also no prizes for guessing which complete numpty forget to check the float heights before installing the carbs! And it was all going so well :oops: I have ordered a second fuel tank to hang alongside the other asit seems the less hassly option.
Many thanks for all the advice guys, but I think you've got your work cut out keeping up with my shenanigans.
Blackseven
#7 PostAuthor: Blackseven » Tue Oct 20, 2020 6:48 pm
Worth remembering too that it is very easy to Inadvertently suspend a temporary fuel bottle much higher than the normal tank level, giving an increased head of pressure which can overwhelm the float needle valve, particularly if old. Try and get the temporary supply suspended at a similar height to the tank to avoid potential issues.
steve452
#8 PostAuthor: steve452 » Tue Oct 20, 2020 7:09 pm
Cheers for that Blackseven...didn't think of that at all. Obvious if you think about it but I'm certainly not doing much thinking at the moment, just a lot of screaming and shouting :cry:
As you guys can see from the pics, I discovered why the overflow pipes were pissing fuel on carbs #1 & 2. I actually got the carbs off the bike and adjusted the float on carb #1 to spec with the clear pipe tool but the overflow still leaked. Then I checked the brass overflow tube in the float bowl itself, and this is what I found on both #1 and #2. Checking #3 and #4 I found that they were, fortunately, both OK. I have a spare carb set and the #1 and #2 float bowls on those look OK so I will do the fuel fill/bubble test tomorrow.
Does anyone know if it's possible to repair the hairline splits in these overflow tubes or is it possible to remove them and get new brass tubes fitted?
#9 PostAuthor: kev edwards » Tue Oct 20, 2020 7:13 pm
This is what i done.
steve452
#10 PostAuthor: steve452 » Tue Oct 20, 2020 10:35 pm
Where do you get them?
#11 PostAuthor: kev edwards » Wed Oct 21, 2020 6:37 am
I made them.
steve452
#12 PostAuthor: steve452 » Wed Oct 21, 2020 11:03 am
Very impressive.
1) How are the genuine ones fitted. Are they a press fit or threaded like yours?
2) How do you stop the fuel leaking along the threads?
3) Can you make some for me? If so...
...4) (sitting down) how much?
walshyco
#13 PostAuthor: walshyco » Wed Oct 21, 2020 12:16 pm
You could just solder them up and then pass a drill bit through by hand to clean them out.
#14 PostAuthor: kev edwards » Wed Oct 21, 2020 12:30 pm
Genuine are push fit, inner and outer are separate pieces, I use a twist of ptfe tape to keep them sealed, they are made in two parts, never thought about making them for others, I guess I could make the odd one or two.
steve452
#15 PostAuthor: steve452 » Wed Oct 21, 2020 1:13 pm
I think you could be onto a winner there Kev considering 2 out of my 4 carbs had split overflow tubes. I'll hang fire for the moment and go with Walshyco's option first.
Users browsing this forum: moizeau and 56 guests
