pistons
Simon Jones
pistons
#1 PostAuthor: Simon Jones » Thu Dec 31, 2020 4:25 pm
I have a 1170 wisco kit and and oil ring has picket up
Does any one know if i can get a .25 mm oversize piston kit instead of going out to 1260 cc which i believe is the next piston size wisco do
Thanks in advance
Simon
75 z1b 75 h2c z1100r rd400 z1000a1 TS125
Re: pistons
#2 PostAuthor: Al » Thu Dec 31, 2020 6:57 pm
There is no oversize for the 1170 kit, it bores std liners 'till nearly transparent. Next one up requires oversize liners. Cheapest way out is another 1100 liner and have that bored to the piston size you have.
What has been damaged? Liner or piston also?
Simon Jones
Re: pistons
#3 PostAuthor: Simon Jones » Fri Jan 01, 2021 8:41 am
It is 3 liners pistons seem ok
Simon Jones
Re: pistons
#4 PostAuthor: Simon Jones » Fri Jan 01, 2021 3:36 pm
DOES any other piston manufacturers make pistons slightly smaller iv always been concerned about the boor thickness
zippy
Re: pistons
#5 PostAuthor: zippy » Fri Jan 01, 2021 4:33 pm
1136 kits from both Wiseco and MTC.
Re: pistons
#6 PostAuthor: Al » Fri Jan 01, 2021 9:28 pm
18mm
zippy
Re: pistons
#7 PostAuthor: zippy » Fri Jan 01, 2021 11:09 pm
MTC it is then.
Simon Jones
Re: pistons
#8 PostAuthor: Simon Jones » Sat Jan 02, 2021 11:58 am
Thank again for all your help i got a set of std barrels from Zippy top man and a MTC 1136 piston kit from pitstop in the states
Users browsing this forum: No registered users and 151 guests
