Z650 fuel linkage O rings
I am looking to put new O rings on the three metal fuel linkage pipes that fit between the carbs on a Z650B1, one T piece and 2 straight pieces.
(92005-1010 & 92005-1009)
They seem to be the same sizes so need 12 O rings in total. Anyone know what sizes O rings I need or where I can get them from? You can buy the complete parts from Z-Power and CMS but they are pretty expensive.
Thanks for any help
Matt
Thanks for any help
Matt
Matt C
Z1000J2 / ZRX1200R / Z650B1 / GPz1170B1 x 2
Re: Z650 fuel linkage O rings
7.5 id x 1.8 cross section give or take have a troll around 'O' ring suppliers you should find something close to that, the ports are around 11mm id from memory. If I am incorrect somebody will be along to let you know
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
if you still have the original joints fitted the part that looks like an o ring is part of the fitting & cannot be removed. you will have to purchase the stainless steel kit that you can buy from z power & has separate o rings fitted
- warren3200gt
650 B1's do have removable o rings from new. Later models had o rings moulded into the t and straight piece.
Halfrauds do a viton multi o ring set which has the correct size in it. Cant recall how many in the set so you may need two.
Cheap enough and you get some spares and a stock of other sizes to boot.
PUM 488 June 2023
KeithZ1R wrote:7.5 id x 1.8 cross section give or take have a troll around 'O' ring suppliers you should find something close to that, the ports are around 11mm id from memory. If I am incorrect somebody will be along to let you know
Thanks for the detail Keith...looks about right. Matt
Matt C
z1bman wrote:if you still have the original joints fitted the part that looks like an o ring is part of the fitting & cannot be removed. you will have to purchase the stainless steel kit that you can buy from z power & has separate o rings fitted
No these O rings definitely come off, and the metal parts do look like they are original 43 years old...the sizes that Keith suggested look about right. Thanks, Matt
Matt C
warren3200gt wrote:650 B1's do have removable o rings from new. Later models had o rings moulded into the t and straight piece.
Good suggestion Warren, thanks Matt
Matt C
mattc wrote:KeithZ1R wrote:7.5 id x 1.8 cross section give or take have a troll around 'O' ring suppliers you should find something close to that, the ports are around 11mm id from memory. If I am incorrect somebody will be along to let you know
Just had another measure whilst not under the influence
Keith
mistaken.
mistaken.
KeithZ1R wrote:mattc wrote:KeithZ1R wrote:7.5 id x 1.8 cross section give or take have a troll around 'O' ring suppliers you should find something close to that, the ports are around 11mm id from memory. If I am incorrect somebody will be along to let you know
Just had another measure whilst not under the influencethey are 8mm id and 1.8 cross section
Thanks, I have just checked the od of the grooves in the metal linkage pieces and they are 8.2mm.....so an O ring id of 8mm or slightly less should be good. Cheers
Matt C
- warren3200gt
8 X 2 is the size you want Matt. Nice tight squish fit. They are in the Halfrauds pack.
PUM 488 June 2023
warren3200gt wrote:8 X 2 is the size you want Matt. Nice tight squish fit. They are in the Halfrauds pack.
Thanks Warren. Squishy fit it will probaby be.... Matt
Matt C
kawasaki never made them with a seperate o ring fitted it was moulded to have the same effect as an o ring someone has probably fitted suzuki gs750b fittings that have seperate o rings & are available to buy seperate & are the same size as the kawasaki
- warren3200gt
Yes they did z1bman. Both my 650's have them fitted. One of which I have owned from new. Both are 650 b1's as is Matt's.
PUM 488 June 2023
i worked at cradley for over thirty years as a mechanic & have stripped many of these carbs & have never seen them with removable o rings if they had removable o rings they would be shown in the parts diagrams or parts microfiche. contact dave marsden at z power if you want more confirmation
gs 750b
gs 750b
Users browsing this forum: kawasaki_man and 39 guests
