ST Carburetor
Darren A
ST Carburetor
#1 PostAuthor: Darren A » Wed Feb 17, 2021 6:48 pm
Hello Chaps
I wonder if any of you can help, I have managed to break one the brass tube that I Assume feeds fuel to the choke mechanism, see photo! The Clymer Manual diagram and parts list doesn’t list it, does any one know the correct name for it so I can search for one or if any one knows where I can get one. Thanks in advance.
Re: ST Carburetor
#2 PostAuthor: zed1015 » Wed Feb 17, 2021 6:58 pm
The choke pick up tube isn't and wasn't a separate item so isn't available as a new or replacement part.
You will have to either obtain one from another carb or make one from brass tube.
They are a press fit so not hard to remove.
Put a post in the Wanted ads section and there will probably be a member who has a spare.
Darren A
Re: ST Carburetor
#3 PostAuthor: Darren A » Wed Feb 17, 2021 7:12 pm
Kind of what I thought, I will do as you suggested to se if any one has one, There is a nice set of fully restored carbs on e- Bay But At £950 it’s a bit much :lol: Thanks
8 Valve Mark
Re: ST Carburetor
#4 PostAuthor: 8 Valve Mark » Thu Feb 18, 2021 7:57 am
I've got a spare one if you are still looking? m
Darren A
Re: ST Carburetor
#5 PostAuthor: Darren A » Thu Feb 18, 2021 9:11 am
Hello mark , definitely, If you want PM me and we can sort payment etc. Thanks
8 Valve Mark
Re: ST Carburetor
#6 PostAuthor: 8 Valve Mark » Fri Feb 19, 2021 1:42 pm
hi Darren, unfortunately my spare is too short, so probably not Z related. hopefully your ad in the wanted section will deliver. sorry for the false hope. m
Darren A
Re: ST Carburetor
#7 PostAuthor: Darren A » Fri Feb 19, 2021 3:05 pm
Ok Mark Thanks anyway hopefully someone else will have one.
Users browsing this forum: Bing [Bot] and 98 guests
