Hello Chaps
I wonder if any of you can help, I have managed to break one the brass tube that I Assume feeds fuel to the choke mechanism, see photo! The Clymer Manual diagram and parts list doesn’t list it, does any one know the correct name for it so I can search for one or if any one knows where I can get one. Thanks in advance.
ST Carburetor
Re: ST Carburetor
The choke pick up tube isn't and wasn't a separate item so isn't available as a new or replacement part.
You will have to either obtain one from another carb or make one from brass tube.
They are a press fit so not hard to remove.
Put a post in the Wanted ads section and there will probably be a member who has a spare.
Re: ST Carburetor
Kind of what I thought, I will do as you suggested to se if any one has one, There is a nice set of fully restored carbs on e- Bay But At £950 it’s a bit much
- 8 Valve Mark
Re: ST Carburetor
I've got a spare one if you are still looking? m
Re: ST Carburetor
Hello mark , definitely, If you want PM me and we can sort payment etc. Thanks
- 8 Valve Mark
Re: ST Carburetor
hi Darren, unfortunately my spare is too short, so probably not Z related. hopefully your ad in the wanted section will deliver. sorry for the false hope. m
Re: ST Carburetor
Ok Mark Thanks anyway hopefully someone else will have one.
Users browsing this forum: No registered users and 98 guests
