Sparking on 1 cylinder only
Hawthorn 7
#1 PostAuthor: Hawthorn 7 » Sun Feb 21, 2021 5:52 pm
Hello all, I bought a 1979 Z1000 a few weeks ago. When I collected the bike all was fine, today being nice I thought I’d use it for work. Fired straight away but only firing on 1 cylinder. Quick check round and there is no spark on cylinder 1,3 and 4 and a poor spark on cylinder 2. The previous owner has fitted a aftermarket electronic ignition.
I will take to a local motorcycle mechanic but thought I’d get some feedback.
Re: Sparking on 1 cylinder only
#2 PostAuthor: zed1015 » Sun Feb 21, 2021 6:02 pm
Most likely fouled plugs or damp/shorting leads etc.
Weak spark on 2 indicates that the dual pole coil should be ok to spark 3 so i'd try all the plugs in 2 cap first to see they spark there.
If not it's the plugs , if they do then look at the leads and coil connections.
#3 PostAuthor: Garry.L » Sun Feb 21, 2021 6:30 pm
Stored in a Shed or detached garage?..
It's been VERY cold in recent weeks meaning your bike would have got very cold. In the last few days it's warmed up a lot, so nice warm(er) air hitting your very cold bike causes it to condense making everything you can't see nice and damp.
Users browsing this forum: No registered users and 141 guests
