GPz1100B2 Fuel Pipe.
BAFF1960
#1 PostAuthor: BAFF1960 » Mon Jan 24, 2022 11:54 am
Hi.
Whilst putting my B2 back together noticed that the short moulded fuel feed pipe from the filter to pump had a split in it. Looking for a replacement or an alternative I can adapt. Pt No. 92059-1165.
Alan
GPZ B1-B2 _FUEL PUMP HOSE.png (121.87 KiB) Viewed 3513 times
Simonic
Re: GPz1100B2 Fuel Pipe.
#2 PostAuthor: Simonic » Mon Jan 24, 2022 5:34 pm
This part is no longer available.I could do with one too,it's a real oddball part as it's different diameter at each end and the curves are pretty sharp.I'll be interested to know if anyone has made a good alternative too. Good Luck !
#3 PostAuthor: warren3200gt » Mon Jan 24, 2022 6:14 pm
I think if it were me, I would try sleeving it with fuel proof heat shrink whilst looking for a replacement.
These guys do all kinds of pre moulded shapes and straight fuel proof heatshrink.
https://www.pmgcompanyonline.com/produc ... eat-shrink
Or run a piece of braided pipe so it doesn't kink.
johnA
#4 PostAuthor: johnA » Mon Jan 24, 2022 8:50 pm
there's someone on the 750turbo forum used a H**** civic part off the cooling system though so don't know if it will stand up to the fuel for long
#5 PostAuthor: z1bman » Mon Jan 24, 2022 9:37 pm
something like this will do the job if you remove the fittings
https://www.ebay.co.uk/itm/133942492790 ... ondition=4
#6 PostAuthor: Al » Mon Jan 24, 2022 9:38 pm
As a temp solution til something more permanent comes along; something like the one on the G1 which is similar but made in two parts with a ferrule joiner in between.
#7 PostAuthor: z1bman » Mon Jan 24, 2022 10:00 pm
Al wrote:As a temp solution til something more permanent comes along; something like the one on the G1 which is similar but made in two parts with a ferrule joiner in between.
no longer available
#8 PostAuthor: deka » Thu Jan 27, 2022 12:53 pm
I had a similar issue with the A1 had 2 pieces of the different pipe and then joined them using a reducer, not pretty but it worked and is out of sight
https://www.ebay.co.uk/itm/281671172701
Simonic
#9 PostAuthor: Simonic » Thu Jan 27, 2022 4:29 pm
johnA wrote:there's someone on the 750turbo forum used a H**** civic part off the cooling system though so don't know if it will stand up to the fuel for long
I think the fuel system is differnt on the turbo John.
https://www.kawasaki.com/en-us/owner-ce ... PARTBUCKET
I hope that link will work !!
Simonic
#10 PostAuthor: Simonic » Thu Jan 27, 2022 4:30 pm
I wonder how much of a chore it would be to get a batch of these made?
Has anyone done anything like this before ?
BAFF1960
#11 PostAuthor: BAFF1960 » Sun Feb 06, 2022 6:31 pm
Hi.
Came up with a solution for or the pump supply pipe replacement. Nothing like original but perfectly acceptable.
Space is a bit tight there so looked for some thing short to fit in that would step up from 8mm to 10. Acquired a plastic 90 degree elbow but that was bit long and plastic for my liking.
Ended buying a pair 8 and 10mm stumpy brass 90 degree fittings and adapted/soldered them together to make the very short step up. See pics. [ I know the filters upside down. ] Easy fix at a cost of a tenner.
Simonic
#12 PostAuthor: Simonic » Sun Feb 06, 2022 7:03 pm
Nice bit of work there mate
Tony
#13 PostAuthor: Tony » Sun Feb 06, 2022 10:08 pm
Very nice simple but effective 10 out of 10 for effort and back in buisnes
