Z1000st
z1r
Z1000st
#1 PostAuthor: z1r » Thu May 12, 2022 9:57 am
Hi, was just wondering is it possible to convert a Z1000 chain drive engine to a shaft drive engine.
thanks michael
Gus
Re: Z1000st
#2 PostAuthor: Gus » Thu May 12, 2022 11:01 am
Sorry my dyslexia kicked in and read the question back to front.
So I have some shaft drive parts left over that I don't need
Gus
"Set the GRINDER on it"
Re: Z1000st
#3 PostAuthor: zed1015 » Thu May 12, 2022 11:50 am
Yes! But only using the ST/MK2 square cam cover cases or later Z1000J /GPZ cases and relevent parts from the equivalent Shaft drive model of the same engine type..
Early 900 and 1000 round camcover models up to the Z1R D1 didn't have a shaft model in the range so can't be converted.
The difference preventing this is that the transmission covers bolt pattern is different on the earlier engines and the later shaft models bevel gear case doesn't fit.
z1r
Re: Z1000st
#4 PostAuthor: z1r » Thu May 12, 2022 12:17 pm
thanks to Gus and Zed 1015 for your response to the question thats answered that question, so does the cases need to be split to do the conversion.
thanks michael
Re: Z1000st
#5 PostAuthor: Philippe » Thu May 12, 2022 12:29 pm
Hi z1r
yes you must split the cases because you have to change the output shaft.
What engine are you going to use to convert from chain to shaft?
As zed1015 says you'll have to use a MK2 or H engine to convert. The other cases (Z900 or Z1000A1/A2) won't work.
If you use a MK2 or H engine case, you'll need an ST gear change.
I think it will be much easier to find a second hand ST engine, those can easily be found.
z1r
Re: Z1000st
#6 PostAuthor: z1r » Thu May 12, 2022 1:27 pm
Hi philippe,
ive got a few mk2 and j engines but want a shaft drive engine that was the reason for the question as i could not find any shaft drive engines readily available.
thanks michael
Gus
Re: Z1000st
#7 PostAuthor: Gus » Thu May 12, 2022 2:14 pm
Try John Browse motorcycles.
01978 355556
Well known for having Z stuff
Re: Z1000st
#8 PostAuthor: ADRIAN H » Fri May 20, 2022 6:23 pm
Edited- not sure what happened there. Answer to a different post. I’ll get my coat.
Re: Z1000st
#9 PostAuthor: zed1015 » Fri May 20, 2022 10:45 pm
ADRIAN H wrote:Ben Day @ vapourworx, overhauled my Z1B carbs, top notch.
http://www.vapourworx.co.uk/
Random :?? :rir
Re: Z1000st
#10 PostAuthor: ADRIAN H » Sat May 21, 2022 8:49 pm
zed1015 wrote:
Random :?? :rir
Having a senior moment, what a plonker. oops:
DeadZedDave
Re: Z1000st
#11 PostAuthor: DeadZedDave » Fri May 27, 2022 8:42 am
Re:Z1000ST - Twowheelspares e-bay shop has a Z1000 ST bottom end listed at the moment. Looks like all you need..... ?
Users browsing this forum: Google [Bot] and 70 guests
