Z1000/ z1r 28mm carbs
Hobbo
International Rep
#1 PostAuthor: Hobbo » Thu Aug 25, 2022 8:25 am
Guys
As title says after a tidy set of 28mm carbs to fit z1000 a1/a2
Not bothered about need bit of cleaning but not knackered ones
Plus can't afford mint restored ones
Phil
International Rep
tightwad
Re: Z1000/ z1r 28mm carbs
#2 PostAuthor: tightwad » Sun Aug 28, 2022 7:02 pm
are these any good, they are 28mm carbs, not sure if z1r but i put new keyster kits in to suit z1r and choke plungers have been done by rob meggit. choke holding screw is missing. looking for £250
ken
Hobbo
International Rep
#3 PostAuthor: Hobbo » Mon Aug 29, 2022 10:35 am
Hi thanks for that I have just paid for some this morning but will keep details
International Rep
Hobbo
International Rep
#4 PostAuthor: Hobbo » Mon Aug 29, 2022 10:35 am
Guys
Prob sorted now thanks
Phil
International Rep
tightwad
#5 PostAuthor: tightwad » Mon Aug 29, 2022 6:09 pm
no worries, i did measure them to make sure they were 28mm and they are 29mm :?:
ken
#6 PostAuthor: zed1015 » Mon Aug 29, 2022 6:29 pm
tightwad wrote:no worries, i did measure them to make sure they were 28mm and they are 29mm :?:
ken
No! They are 28mm.
They are sized by the width at the narrowest point in the venturi which is usually the bore closest to the needle jet.
The venturi tapers out toward the outlet so vm26 measure around 27mm and vm28 around 29mm at that point.
tightwad
#7 PostAuthor: tightwad » Tue Aug 30, 2022 6:50 pm
thanks for the explanation, never thought of them being tapered :up
ken
walshyco
#8 PostAuthor: walshyco » Thu Sep 01, 2022 12:45 pm
Interested, PM sent.
