Rev Counter Refurb Needed
Tonka
#1 PostAuthor: Tonka » Thu Feb 02, 2023 6:20 pm
Hi, who would you recommend to refurbish a Z1R rev counter? The face has faded and the casing needed a paint. It's going on a Z1R that I am doing up to 'as new' condition the rev counter will be letting it down now
Inheritance? What inheritance? He spent it all on booze, women and Zed parts!
Re: Rev Counter Refurb Needed
#2 PostAuthor: Garry.L » Thu Feb 02, 2023 7:25 pm
Will Barber on here does excellent repo Gauge faces for most makes/models.
compo z1r
#3 PostAuthor: compo z1r » Thu Feb 02, 2023 8:57 pm
Tonka wrote:Hi, who would you recommend to refurbish a Z1R rev counter? The face has faded and the casing needed a paint. It's going on a Z1R that I am doing up to 'as new' condition the rev counter will be letting it down now
do -it-ur self ?
da clok2.jpg (119.57 KiB) Viewed 4390 times
da clok.jpg (126.35 KiB) Viewed 4390 times
da 3.jpg (121.89 KiB) Viewed 4390 times
clock 7.jpg (96.94 KiB) Viewed 4390 times
8 finished.jpg (75.79 KiB) Viewed 4390 times
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
rpeters
Bristol's "H" Hoarder
#4 PostAuthor: rpeters » Fri Feb 03, 2023 6:52 am
How do you get the crimp rings off without damaging them. Is there a special tool?
paid up member
compo z1r
#5 PostAuthor: compo z1r » Fri Feb 03, 2023 6:17 pm
rpeters wrote:How do you get the crimp rings off without damaging them. Is there a special tool?
their may b one rob but ive made my own inc the set up to hold the clocks and then to refit ring ?
gray
#6 PostAuthor: gray » Fri Feb 03, 2023 6:56 pm
Peter Bond rebuilt my speedo after the face broke in 2. However, the texture of the face came back ripply not smooth. So if you choose him that's a point to mention
gray
rpeters
#7 PostAuthor: rpeters » Sat Feb 04, 2023 8:10 pm
Who is Peter bond?
paid up member
#8 PostAuthor: Bill P » Sat Feb 04, 2023 10:22 pm
#9 PostAuthor: ADRIAN H » Sun Feb 05, 2023 5:49 pm
Small flat head screwdriver is all I have ever used.
Z-fever in Germany used to sell replacement crimp rings. To order you’ll have to send an email telling him what you require and asking him for a PayPal money request.
Tonka
#10 PostAuthor: Tonka » Sun Feb 19, 2023 11:07 am
Don't Z Clocks in Tamworth do them any more?
Tonka
#11 PostAuthor: Tonka » Sun Feb 19, 2023 11:26 am
do -it-ur self ?
Where did you get the tacho clock face from?
Gray17
#12 PostAuthor: Gray17 » Sun Feb 19, 2023 6:55 pm
If you see my post you will see i did do it myself, trim rings come off by carefully inserting a small screwdriver under the lip on the rear, then using a tin opener type movement work your way around a bit at a time, takes a lot of time and patience but eventually they come apart. I hought my new faces from a company in Holland (cb750 faces.com) they are very good quality and can have either green or white backing depending on backlighting reqd.
They also sell the new glass cut to 88mm and new trim rings if needed.
The main problem i found after 47 years the rubber gaskets had lost their softness and were hard, so when taking them apart they get damaged if not careful, once apart soak them in hot water, then smear with silicone grease helps restore them.
I have conpleted mine, replaced faces, new glass and using original trim rings, re fitting them is still ongoing, as trim rings are very tight, new ones would be better but apart from cost you would need a proper tool to do them right, once theyv been bent the will re bend a lot easier, just need to find a way to compress the 2 halves whilst i i refit them. All would be well if i had been born an octopus as 8 hands would have helped Ha! Maybe not
compo z1r
#13 PostAuthor: compo z1r » Sun Feb 19, 2023 7:47 pm
Tonka wrote:
do -it-ur self ?
will barber has them all { big fluff on here }
