cam timing....
Peteypops23
Re: cam timing....
#31 PostAuthor: Peteypops23 » Mon May 01, 2023 3:35 pm
Will do....cheers Al.
Stagman
Re: cam timing....
#32 PostAuthor: Stagman » Sat Jun 24, 2023 8:32 pm
Hi guys,
I'm checking the cam timing on my A4. Looking at Andys timing marks he has the same as mine, i.e. in clockwise order the marks are T 1 f 4. The cam timing mark i assume is the T which is the 1st mark of the 4 marks.
However when you look in the manual, the T mark is the 2nd mark of the series of 4, as it shows 1 T F 4 and the T mark in the manual is aligned with the casing mark for cam timing, so in summary the manual timing mark is the 2nd position of the 4 marks, where as Andy has shown his lining up with the first mark, making the 2 settings in different positions within the series of 4 marks.
Hope that makes sense?
Can anyone confirm if we use the T mark regardless of it's position in the series of 4 marks please?
Many grateful thanks
Mark
Re: cam timing....
#33 PostAuthor: zed1015 » Sat Jun 24, 2023 10:20 pm
The T mark is Top dead center.
The 1 - 4 just indicates which two cylinders are at TDC or firing when those marks line up with the mark on the cases.
The actual order of the 1 - 4 ( or 2-3 ) in relation to the T and F doesn't matter.
Stagman
Re: cam timing....
#34 PostAuthor: Stagman » Mon Jun 26, 2023 3:03 pm
Thought so but good to get it crystal clear.
Thanks for the help
Users browsing this forum: No registered users and 83 guests
