z500 Swinging arm
olnmfc
z500 Swinging arm
#1 PostAuthor: olnmfc » Thu Nov 23, 2023 8:15 am
Anyone know of an alloy one available? Cheers
Big Fluff
Re: z500 Swinging arm
#2 PostAuthor: Big Fluff » Fri Nov 24, 2023 3:35 pm
John Browse will have one for sure.
olnmfc
#3 PostAuthor: olnmfc » Fri Nov 24, 2023 4:07 pm
Cheers Big Fluff - I gave him a call but no joy. Might be a tricky thing to find, altho Im guessing z550 or Gpz550 will also fit. I think they do exist as Im sure Ive seen photos online of examples
gray
#4 PostAuthor: gray » Fri Nov 24, 2023 7:57 pm
Dresda used to do a steel box section one like the one on my Zed. The person who bought all Dresda's stock had a bedroom full of swingarms , all unlabelled tho , he told me 10 years ago.
Early GPz 550 ( twinshock), z550 should fit too.
Thinking laterally, I see there are alloy copy swingarms for various bikes , and the ebay listing says they can be bought from Thailand. If only you knew someone from there.... :D. Take yours there so they can see the measurements and get an alloy one made up
gray
Big Fluff
#5 PostAuthor: Big Fluff » Mon Nov 27, 2023 3:50 pm
This crusty example from a Z550 is available :roll:
https://www.ebay.co.uk/itm/152675229685 ... ondition=4
olnmfc
#6 PostAuthor: olnmfc » Mon Nov 27, 2023 8:32 pm
Ha! Interesting - I also got reply from Z Power and Kawasaki Heaven - no joy. Metmachex site says they stopped making swing arms in 2017, but their website does feature various big Kawa examples, so might drop them a note next... altho I was tempted by a z650 B3 alloy swinging arm, which came with a complete nice bike attached to it also, but was a bit far away
#7 PostAuthor: Z1streetfighter71 » Mon Nov 27, 2023 10:01 pm
olnmfc
#8 PostAuthor: olnmfc » Tue Nov 28, 2023 10:38 am
It might fit, maybe with mods. Might be the only way. looks like wheelbase would be extended a few cm. They have been done - here's a underbraced z550 one (maybe based on the zepher) and a z400 turbo
400 Turbo
z550 racer
#9 PostAuthor: Z1streetfighter71 » Tue Nov 28, 2023 12:28 pm
I have one handy if you want to measure what you have vs the the the Zephyr width. Plus i know a lad that has a JMC braced swing arm for a Z650.
olnmfc
#10 PostAuthor: olnmfc » Tue Nov 28, 2023 1:22 pm
yes I presume that old swinging arm is a z500/550? so could measure each width and length. I could check against mine too?
#11 PostAuthor: Z1streetfighter71 » Tue Nov 28, 2023 2:30 pm
olnmfc wrote:yes I presume that old swinging arm is a z500/550? so could measure each width and length. I could check against mine too?
Yea mate, measure what you have in width of axle pivot including any spacers. Length from both the wheel axle and the width between the swingarm arms and ill do the same for you if you want.
#12 PostAuthor: Z1streetfighter71 » Tue Nov 28, 2023 2:32 pm
Side note the Zephyr real wheel is 140/70/18
olnmfc
#13 PostAuthor: olnmfc » Wed Nov 29, 2023 2:59 pm
seems approx 23cm wide and 46 cm long to mid chain adjuster slot. Seen online that bigger Z Zepher swing arm swaps need bushes made to accommodate smaller spindle
#14 PostAuthor: Z1streetfighter71 » Wed Nov 29, 2023 7:08 pm
olnmfc wrote:seems approx 23cm wide and 46 cm long to mid chain adjuster slot. Seen online that bigger Z Zepher swing arm swaps need bushes made to accommodate smaller spindle
Bushings are easy enough to have made up by someone local or even someone on here, the width of the swingarm is more important so it fits the frame with enough room for spacers. Ill throw a measurement on it tomorrow to be certain of numbers. If its alloy and light and not braced then the Gs1100E is a go to for a lot of lads but hard to find and a wee bit pricey these days.
j.b
#15 PostAuthor: j.b » Sat Dec 30, 2023 11:02 am
I have a gpz550 mono shock (unitrak) arm here if you’re happy to weld on a pair of twin shock mounts? Let me know if you’re interested and I’ll send you some pictures over
