Hydraulic clutch Slave Cylinder.....
Marco Polo
#1 PostAuthor: Marco Polo » Fri Nov 01, 2024 2:33 pm
Help! Recently purchased a 75 Z1B that had all the mods we used to fit back in the day. Brembo twin discs/4 into 1 etc. It has an Hydraulic clutch and the slave cylinder has a failed seal. I can't work out the make or type to try find a replacement of seal kit. It looks very similar to a GSF1200
Can anyone out there assist in identification?
Gus
Re: Hydraulic clutch Slave Cylinder.....
#2 PostAuthor: Gus » Fri Nov 01, 2024 2:46 pm
Looks like kawasaki
"Set the GRINDER on it"
steady eddie
#3 PostAuthor: steady eddie » Fri Nov 01, 2024 2:51 pm
Same as Gus zxr750 or zx7r as fitted to my 1262
Marco Polo
#4 PostAuthor: Marco Polo » Fri Nov 01, 2024 3:07 pm
I've looked around and the Kawasaki ZX10 slave looks identical but still not sure.......... It's a three bolt fixing so yours looks like a 2 bolt
Thanks for the input Steady... Here's the Zed
Hard Road
#5 PostAuthor: Hard Road » Fri Nov 01, 2024 4:51 pm
its not a bandit GSF one, they are 2 bolt.
#6 PostAuthor: zed1015 » Fri Nov 01, 2024 5:19 pm
The three bolt one is GPZ900R / GPZ1000RX/ ZRX1100-1200 / ZZR1100 / GTR1000 etc, etc, etc.
Marco Polo
#7 PostAuthor: Marco Polo » Fri Nov 01, 2024 9:06 pm
Thanks for the input guys, we'll have a try with the ZX10 which seems the closest match unless anyone out there has any better plan!
#8 PostAuthor: z1bman » Sat Nov 02, 2024 6:25 pm
its a ZZR1100 D model slave cylinder
#9 PostAuthor: ADRIAN H » Sat Nov 02, 2024 7:19 pm
zed1015 wrote:The three bolt one is GPZ900R / GPZ1000RX/ ZRX1100-1200 / ZZR1100 / GTR1000 etc, etc, etc.
This is the correct answer. As I have a ZRX1200 one on my Zed.
Foxfix
#10 PostAuthor: Foxfix » Sun Nov 03, 2024 3:37 pm
We fit these to the Z1300 as a modification.
As someone mentioned earlier, its the same as :-
