Z1000 LTD to standard
dixiethedog
Re: Z1000 LTD to standard
#166 PostAuthor: dixiethedog » Sun Jan 26, 2025 3:00 pm
OOPs! I have just spotted your post saying that you have one on its way.
Every silver lining has a cloud...
Hard Road
#167 PostAuthor: Hard Road » Sun Jan 26, 2025 3:12 pm
dixiethedog wrote:Loving the build. :D
If you could use a Mk2 600 front wheel I have one kicking around here that you could have. But as you no doubt know, the Mk2 does not have a speedo drive.
cheers mate :wink:
ive got a Mk1 600 wheel on its way as they are 3inch and use a 110 tyre, the Mk2 is 3.5 inch and uses a 120 tyre, i already have a B12 wheel thats the same size as the B6 Mk2 but wanted the slightly slimmer wheel. (although the B12 wheel fits in) but the Mk1 B600 wheel has the curved spokes to match the rear already fitted.
by the way the Mk2 600 and 1200 wheels have the notches in the hub for the speedo drive, they just use a spacer in stead as the Mk2 as you know has an electronic speedo. :wink:
dixiethedog
#168 PostAuthor: dixiethedog » Sun Jan 26, 2025 3:39 pm
I had no idea that a mk2 600 wheel was wider than a Mk1 erm... one.
Funnily enough (to me at least) was that I have just come in from my "shed" where I have been machining spacers in readiness to fit a bandit wheel to a set of GSXR1000 (2018) forks. With your info regarding a 600 wheel being 3.5 inches, I may well be able to use that rather than having to strip a 1200 front end of its wheel.
I love your build thread as it inspires me to pull my finger out. I have a z650 frame (that had been fitted with a Z1 tank), I have a Z1 tank, a spare engine or three (but they are more OSS than zed) so in theory, I could build a nice non original zed.
One day.
Hard Road
#169 PostAuthor: Hard Road » Sun Jan 26, 2025 4:16 pm
dixiethedog wrote:I had no idea that a mk2 600 wheel was wider than a Mk1 erm... one.
One day.
I like building "mongrels" this is the fourth Zed ive done ( 2 with bandit engines) and other Suzuki parts. I'd like to see your builds ?
I think the second Zed I built was the best but like an idiot I sold it :roll:
this one.
Hard Road
#170 PostAuthor: Hard Road » Mon Jan 27, 2025 2:20 pm
still waiting for the wheel to turn up !!! but I have a pair of Nissin 4 pot callipers off a 1200 bandit i was gona use, they need a strip down and a fresh coat of paint, but came across a pair of Nissin 2 pots of a modern Z650, so bought them, they are in near mint condition and very cheap, thought it more fitting to use Kawasaki parts :D will need a mounting bracket making though.
Hard Road
#171 PostAuthor: Hard Road » Mon Jan 27, 2025 5:52 pm
also while i was waiting for the 600 wheel i put the 1200 one in and used it as a guide to adjust the chrome zed mudguard. redrilled the mount holes and cut off the rest. wanted to keep the chrome look. :)
Hard Road
#172 PostAuthor: Hard Road » Thu Jan 30, 2025 2:31 pm
wheel finally turned up (fecking Evri) B12 disc's fitted and cardboard template made for calliper mounts, just waiting for some 10mm ally plate. still need to sort out some sort of speedo drive !!!! will try and reduce a B6 one down enough to fit ?? then its practically done. happy with the look so far. :)
Hard Road
#173 PostAuthor: Hard Road » Sat Feb 01, 2025 3:16 pm
one calliper mount bracket made, just need to copy it for the other side, job for tomorrow. also modified the B6 speedo drive to fit, so pretty much done.
Andy M
#174 PostAuthor: Andy M » Sat Feb 01, 2025 4:54 pm
Does the speedo cable match the Z clocks ?
Hard Road
#175 PostAuthor: Hard Road » Sat Feb 01, 2025 6:04 pm
Andy M wrote:Does the speedo cable match the Z clocks ?
it does Andy :wink:
Hard Road
#176 PostAuthor: Hard Road » Mon Feb 03, 2025 12:03 pm
on its new wheels :) happy with it, just needs a road test but its still very wet and salty where I am :( looks much better :wink:
marmck
#177 PostAuthor: marmck » Mon Feb 03, 2025 3:20 pm
That looks tasty!
Hard Road
#178 PostAuthor: Hard Road » Mon Feb 03, 2025 3:29 pm
marmck wrote:That looks tasty!
cheers marmck :wink:
give it a little run round the block, everything seems ok, but one BIG difference is the front brakes, the pads are not bedded into the disc's yet but they work soooooo well :D 2 finger braking, and they'll only get better :mrgreen:
DeadZedDave
#179 PostAuthor: DeadZedDave » Mon Feb 03, 2025 4:33 pm
The old Zed looks pretty sharp (again !) Is it "finished" :D Nice job !!
Hard Road
#180 PostAuthor: Hard Road » Mon Feb 03, 2025 5:47 pm
DeadZedDave wrote:The old Zed looks pretty sharp (again !) Is it "finished" :D Nice job !!
cheers Dave, yeah pretty much done, nothing else I want to change really, just need to sort a chainguard as i havent got one. if anything it'll be some mild tuning, got an air corrector kit that I'll fit with different jetting, but don't know if I want to ditch the airbox or not ? and do away with the points. :wink:
Users browsing this forum: Richard Q and 47 guests
