gpz1100 oil pan
johnA
gpz1100 oil pan
#1 PostAuthor: johnA » Fri Apr 04, 2025 3:03 pm
Hello gents can anyone please tell me if it's possible to change the oil pan without removing the engine please.
Many thanks in advance John
Re: gpz1100 oil pan
#2 PostAuthor: zed1015 » Fri Apr 04, 2025 3:55 pm
Yes! Once the exhaust has been removed.
johnA
Re: gpz1100 oil pan
#3 PostAuthor: johnA » Fri Apr 04, 2025 4:57 pm
Thanks Rob is there anything to catch you out inside or is it just a straight swap.
Re: gpz1100 oil pan
#4 PostAuthor: zed1015 » Fri Apr 04, 2025 5:09 pm
If it's just a straight swap because the pan is damaged then it's simply unbolt the old and bolt on the replacement with a new gasket.
While the pan is off i would check out the oil pump screen and see if it needs cleaning .
The pump is fixed with 3 bolts and easily removed if needed.
johnA
Re: gpz1100 oil pan
#5 PostAuthor: johnA » Fri Apr 04, 2025 5:34 pm
Thank you very much Rob
Users browsing this forum: No registered users and 97 guests
