KZ1000 1981/82 Engine.
Foxfix
#1 PostAuthor: Foxfix » Thu Apr 17, 2025 8:46 am
Is it common or regular to get a light "Tick" on the above engines from the Ignition Pick-Up area ?
It can only really be heard on idle and not above.
Its NOT leaking exhaust gaskets.
Its NOT valve shims.
Any productive and useful advice appreciated.
Re: KZ1000 1981/82 Engine.
#2 PostAuthor: zed1015 » Thu Apr 17, 2025 8:57 am
Could be anything but it's not a normal characteristic of the J/GPZ engine variation.
#3 PostAuthor: Z1streetfighter71 » Thu Apr 17, 2025 9:29 am
Have you done an oil change of late? Any obvious signs of metal in the oil, did you run the bike with the points cover off?
Foxfix
#4 PostAuthor: Foxfix » Thu Apr 17, 2025 10:00 am
Everything has been doen in the last 200 miles.
Oil Filter/ Air Filter / Oil / Plugs / Shims...........etc.
Have not ran with pick-up cover removed..........but what difference would that make ?
#5 PostAuthor: Z1streetfighter71 » Thu Apr 17, 2025 11:35 am
Foxfix wrote:Everything has been doen in the last 200 miles.
It might make the sound more audible and maybe it could be coming from in it...can never rule things out.
Foxfix
#6 PostAuthor: Foxfix » Thu Apr 17, 2025 1:21 pm
Thanks for suggestion !
Users browsing this forum: moizeau and 38 guests
