Stainless steel engine to frame bolt kit ?
Mrg
#1 PostAuthor: Mrg » Fri Apr 18, 2025 4:49 am
Does any one do these in stainless not the engine casing/covers set but the bolts that hold the engine to the frame
Z1000st.
If not is there any problem with using fully threaded bar or would it be better to get un- threaded bar and cut my own threads these would be for the longer bolts I believe the one at the front of the engine would be 310mm long.
Mally
Re: Stainless steel engine to frame bolt kit ?
#2 PostAuthor: Mally » Fri Apr 18, 2025 6:47 am
Try here mate , got loads of bolts etc from them over the years .
https://fixabolt.co.uk/collections/m10- ... eaded-10mm
#3 PostAuthor: zed1015 » Fri Apr 18, 2025 7:03 am
Whatever you do don't use allthread/threaded bar, It will chew into the alloy and where it passes through the frame.
I either buy suitable length bolts as in the link in the above post or make my own from stainless bar and thread the ends.
#4 PostAuthor: ADRIAN H » Fri Apr 18, 2025 2:03 pm
Talk to Z power they’ll sort you out.
Mrg
#5 PostAuthor: Mrg » Wed Apr 23, 2025 5:12 am
Cheers guys got everything sorted now couldn't find a 310mm stainless bolt for the front but will have to get a 400mm bolt and cut and thread to size.
Users browsing this forum: No registered users and 138 guests
