Z1r rear frame
Tony
Re: Z1r rear frame
#31 PostAuthor: Tony » Tue Apr 29, 2025 8:49 pm
Yes you’re correct the front seat mounts and the left hand pillion peg mount
Tony
Re: Z1r rear frame
#32 PostAuthor: Tony » Tue Apr 29, 2025 8:51 pm
Hey compo is that your red frame
Re: Z1r rear frame
#33 PostAuthor: Z1streetfighter71 » Wed Apr 30, 2025 7:23 am
Tony wrote:Yes you’re correct the front seat mounts and the left hand pillion peg mount
I’m in the same boat, I’m missing seat brackets, turn signal ears and the seat latch on one of my frames along with the light bracket. I figured all of those things were unobtainable so I drew my own. This is currently being cut right now. I’ve decided to try and make my own light bracket. Still doing the drawing for that one.
Tony
Re: Z1r rear frame
#34 PostAuthor: Tony » Wed Apr 30, 2025 9:24 pm
Hi street fighter keep us posted how things turn out looks like it will be a big job cheers tony
compo z1r
Re: Z1r rear frame
#35 PostAuthor: compo z1r » Thu May 01, 2025 11:54 am
Light bracket ? Rear ?
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
compo z1r
Re: Z1r rear frame
#36 PostAuthor: compo z1r » Thu May 01, 2025 11:58 am
U want one of these as original u will have to extend indicator stem or renew easy or use as is tail tidy ?
https://www.ebay.co.uk/itm/396474629503 ... media=COPY
Re: Z1r rear frame
#37 PostAuthor: Z1streetfighter71 » Thu May 01, 2025 5:49 pm
Yea mate same as tony but not missing as much. , i have one frame from the indicators back missing but void of any brackets or mounts and another frame missing the seat latch and mounts. ill fabricate most of it as im fairly good with the fiddly bits as i used to design and build tattoo machines for many a year.
compo z1r
Re: Z1r rear frame
#38 PostAuthor: compo z1r » Thu May 01, 2025 5:53 pm
:D The z250 has the same light bracket as a z1r but with indicator stalks 24mm a side shorter a lot fitted them back in the day to tidy up back end easy to fix 2 welds ground off and replace tube with one 48mm longer easy done
Re: Z1r rear frame
#39 PostAuthor: Z1streetfighter71 » Thu May 01, 2025 6:17 pm
compo z1r wrote::D The z250 has the same light bracket as a z1r but with indicator stalks 24mm a side shorter a lot fitted them back in the day to tidy up back end easy to fix 2 welds ground off and replace tube with one 48mm longer easy done
I read that about the Z250 light unit, handy in a pinch. Both me and Tony are missing the bracket on the frame, as below.
Screenshot 2025-04-15 at 15-49-33 4afc9bd0-e39b-46f8-8968-25276ccf8956 (JPEG Image 960 × 720 pixels).png
Screenshot 2025-04-15 at 15-49-33 4afc9bd0-e39b-46f8-8968-25276ccf8956 (JPEG Image 960 × 720 pixels).png (805.53 KiB) Viewed 5760 times
compo z1r
Re: Z1r rear frame
#40 PostAuthor: compo z1r » Thu May 01, 2025 6:51 pm
that's part of frame and do's not have a part No though a chap on ebay makes them and toon at the z1r owners register has made one or 2 so can b bought !! make sure the mounts for the cover is correct or the seat lock opening in the cover don't line up with the lock seen it happen ok
