De glaze
Sifu
De glaze
#1 PostAuthor: Sifu » Mon Jun 23, 2025 3:11 am
has anyone de glazed a cylinder head and does Kawasaki have a tool for the job ? Seen this
has anyone use this
DeadZedDave
Re: De glaze
#2 PostAuthor: DeadZedDave » Mon Jun 23, 2025 10:15 am
For De - Glazing CYLINDER BORES I used a tool called Flex Hone.
I've never heard of a "liquid" to do this job (but that means nothing !)
It sounds like a good option. HOWEVER, I'd be inclined to check with Millers before you use it with a roller bearing crank in a Zed. Also, its only 20w. I would not want to run such a light viscosity oil in a Zed motor - not even for a short time.
Re: De glaze
#3 PostAuthor: ADRIAN H » Thu Jun 26, 2025 2:06 pm
Unsure what you are trying to do. De-glazing normally refers to the cylinder bore, using a hone tool.
relisysxx
Re: De glaze
#4 PostAuthor: relisysxx » Fri Jun 27, 2025 6:12 am
Looks like 'running-in' oil to me, used to use it for the first fill in a rebuilt engine back in my Mini days.
Users browsing this forum: Foxfix and 30 guests
