this sits under RH panel; is an aluminium case about 50 x 30 mm in size and there is a small screw in the case (not one of the bolt/screws that holds it to the frame)?
what is the purpose of the screw? (removes aluminium cover)? or some other purpose.
z1000a2 voltage regulator query?
Steve Cooke
- ZedHead
- RALPHARAMA
Steven Cooke wrote:Don't touch that screw as it is an integral part of the regulator and has nothing to do with the casing if you turn it you'll f**ck it.
Is it that much of a turn on, that turning the screw that you would be overcome by such insatiable lust. I hope I didn't throw my old one out
Ralph Ferrand
Steve Cooke
- ZedHead
Users browsing this forum: No registered users and 94 guests
