z1000a2 voltage regulator query?
02GF74
#1 PostAuthor: 02GF74 » Wed Jun 25, 2008 3:41 pm
this sits under RH panel; is an aluminium case about 50 x 30 mm in size and there is a small screw in the case (not one of the bolt/screws that holds it to the frame)?
what is the purpose of the screw? (removes aluminium cover)? or some other purpose.
#2 PostAuthor: Pigford » Wed Jun 25, 2008 6:04 pm
Hmmmmmm, mark it with paint, unscrew it (counting turns - just in case) and see what happens :wink:
Don't forget to report your findings...... :??
Steve Cooke
#3 PostAuthor: Steve Cooke » Wed Jun 25, 2008 6:07 pm
Don't touch that screw as it is an integral part of the regulator and has nothing to do with the casing if you turn it you'll f**ck it.
#4 PostAuthor: Pigford » Wed Jun 25, 2008 6:12 pm
Cheers Steve :oops: ... there you go, as I said, don't touch it :!: :!:
02GF74
#5 PostAuthor: 02GF74 » Thu Jun 26, 2008 8:29 am
^^^ LOL - 's what I thought.
RALPHARAMA
#6 PostAuthor: RALPHARAMA » Thu Jun 26, 2008 11:11 am
Steven Cooke wrote:Don't touch that screw as it is an integral part of the regulator and has nothing to do with the casing if you turn it you'll f**ck it.
Is it that much of a turn on, that turning the screw that you would be overcome by such insatiable lust. I hope I didn't throw my old one out :lol: On second thoughts I won't look, I may be wracked with guilt afterwards, not to mention in misshapen member :lol:
Ralph Ferrand
Steve Cooke
#7 PostAuthor: Steve Cooke » Fri Jun 27, 2008 5:22 pm
Fortunately i'm still turned on by even a little screw. :lol:
Users browsing this forum: Google [Bot] and 39 guests
