oil cooler fitting
dougie
oil cooler fitting
#1 PostAuthor: dougie » Mon Jan 19, 2009 7:03 pm
Hi,
guys,anybody have a diagram for fitting an oil cooler to a Z1.
Thanks,dougie.
#2 PostAuthor: Pigford » Mon Jan 19, 2009 7:09 pm
Dougie..... what you want....... how to fit lines... or mount cooler or what...
If its just connecting the cooler.... you need to swap the standard oil switch unit (rear of barrels under the middle carbs).... & fit a modified pair of take-offs...... :|
Then you just run the s/s braided pipe to the cooler.....
Doesn't matter which way it flows to/from cooler, just make sure you mount it with the cooler connections facing UP :wink:
I have a complete oil cooler set up if you're after one... :twisted:
#3 PostAuthor: Pigford » Mon Jan 19, 2009 7:17 pm
bigmac103
#4 PostAuthor: bigmac103 » Mon Jan 19, 2009 10:43 pm
Just how efficient are oil coolers for the Z engines?
Lost in the desert somewhere
#5 PostAuthor: Pigford » Tue Jan 20, 2009 9:35 am
Coolers are very good... depending on size :wink:
Can be a bit of an overkill depending on engine state :shock:
My black Zed was running real hot without one tho :!:
KWACKERZ1
#6 PostAuthor: KWACKERZ1 » Tue Jan 20, 2009 10:34 am
Pigford,
Obviously Dougie has first dibs, but what do you want of the oil cooler setup as I will be looking for one soon.
What make is the cooler?
What size is it ?
Goodridges?
Does it run around the block or over the top?
PM Me with a price if you like, if Dougie's not interested.
tlc
#7 PostAuthor: tlc » Tue Jan 20, 2009 5:21 pm
Piggy.
How dare you critcise the "rivet counters" you HEATHEN :evil:
I spy those "crimp on - fall off" connectors :shock:
#8 PostAuthor: Pigford » Tue Jan 20, 2009 6:02 pm
TLC, actually those 'dodgy' hose fitting are a bugger, mainly 'coz of the opposite factor... :shock:
They crimp the rubber onto the spigot & usually have to be cut off, they seem to 'weld' themselves to the brass :roll:
#9 PostAuthor: chrisu » Tue Jan 20, 2009 6:37 pm
i think he was referring to the dodgy ELECTRICAL (or not) connectors. :roll:
#10 PostAuthor: Pigford » Tue Jan 20, 2009 7:16 pm
Oh yeah.... :oops:
Got an oil pressure gauge as well :wink:
#11 PostAuthor: Pigford » Wed Jan 21, 2009 6:52 pm
For Dougie...
#12 PostAuthor: Ginger Bear » Mon Mar 09, 2009 8:15 pm
Pigster,
Is this oil cooler set up still up for grabs :?
I can pay with cash or biscuits, or half & half!
#13 PostAuthor: Pigford » Mon Mar 09, 2009 8:22 pm
Sorry GB, you're too slow matey...... :??
#14 PostAuthor: Ginger Bear » Mon Mar 09, 2009 8:28 pm
Story of my life!! :cry: :cry:
