DROUIN Supercharged Z1000A ..
#31 PostAuthor: zed1015 » Fri Jan 30, 2009 12:08 pm
gbh wrote:What colour are you going to paint it?
Hi. Sorry can't say just yet , I have a scheme in mind, A modern twist on an old popular theme. It all hinges on whether the one off tank badges i intend to cast on my coal fire ( when the missus is out shopping ) come out ok.
Murph
#32 PostAuthor: Murph » Fri Jan 30, 2009 1:22 pm
Very very nice it's a beast cant wait to see it finished .
Z9A4, Z1000a1 ZX10B1 ZX10B3 ZZR1100 ZG1200 VOYAGER
ted1r
KNOW
#33 PostAuthor: ted1r » Fri Jan 30, 2009 5:42 pm
ZED1015 I WORK AT CORUS DO YOU?MAYBE OUR PATHS HAVE CROSSED UNKOWINGLY?
TED
Re: KNOW
#34 PostAuthor: zed1015 » Fri Jan 30, 2009 8:09 pm
ted1r wrote:ZED1015 I WORK AT CORUS DO YOU?MAYBE OUR PATHS HAVE CROSSED UNKOWINGLY?
TED
Sorry, don't work at corus.Got a few mates who do though, all who have bikes so you might know some of them. I used to do work freelance for a couple of bike shops in town as a sideline as well as taking in a few jobs at home, Hence the workshop.
#35 PostAuthor: zed1015 » Sat Jan 31, 2009 4:16 pm
Here's some pics and info on the frame mods. This shows the usual undertank bracing. All the tubing used is from a donor GPZ305 frame, so its all genuine kawa.
#36 PostAuthor: zed1015 » Sat Jan 31, 2009 4:23 pm
This show's bracing around swingarm pivot area and also rubber mounted catch tank i've just done.
Also the new swing arm spindle is of a larger dia than original so i rigged up a special cutter (that used the pivot as a guide) to machine out the frame pivot inserts, I then turned up some larger dia replacements and welded them in.
#37 PostAuthor: zed1015 » Sat Jan 31, 2009 4:38 pm
This shows the original rear loop which i repositioned and braced to mount the battery box and seat mount , The rear shock mounts have been re built bringing them wider apart to match the swingarm, Also shown is the alloy seat support plate so that the fiberglass UNATECH Z9 ZEDBUTT seat unit is not taking the weight of my fat a*se.
#38 PostAuthor: zed1015 » Sat Jan 31, 2009 4:50 pm
Bit obvious this one. Substantial (Z) bracing on front down tubes. The fastest bits of geep 305 on the planet :)
#39 PostAuthor: Ginger Bear » Sat Jan 31, 2009 5:10 pm
Beginning to feel my own efforts are a little inadequate after looking at this :ooer
Amazing Bike!
#40 PostAuthor: Pigford » Sat Jan 31, 2009 5:16 pm
Crickey.... bloody loverly..... Great bit of skilled work..... :twisted:
Top notch.... love the use of Mr Kawasaki bracing... & the ZED design :wink:
Jappen
#41 PostAuthor: Jappen » Sat Jan 31, 2009 5:32 pm
Ginger Bear wrote:Beginning to feel my own efforts are a little inadequate after looking at this :ooer
Amazing Bike!
Me to... :shock: :lol:
EXELENT !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :brav
80-Z1000H
79-Z1000MK2
kz900B1
#42 PostAuthor: kz900B1 » Sat Jan 31, 2009 9:45 pm
Looking at the size of that Drouin ,the frame's going to need all that bracing and some .Awesome to see though. :twisted:
colinKZ900B1
#43 PostAuthor: zed1015 » Mon Feb 02, 2009 9:56 am
Exhaust Craft wrote:Very nice,can you get the lathe a bit closer to the bike?
Hi.Exhaust craft. Here's a pic just for you. Got her to pose with the door wide open, OOER ! :oops: . Can provide more pic's in plain brown paper package. :wink:
Exhaust Craft
#44 PostAuthor: Exhaust Craft » Mon Feb 02, 2009 10:12 am
You must have spent some time on the old lathe,making bits for the Z,your bike is going to be a work of art!
I am building a one off at the moment,just the usual upside front end and gsxr swinging arm,no idea when it wll be finished,i am thinking of making a different exhaust for it,i am in the process of sorting the tooling to make 2 into 1s,so i can make a exhaust system that can stay on so the oil can be changed,the system i make at the moment looks good but obviously need removed to service the bike.
#45 PostAuthor: zed1015 » Mon Feb 02, 2009 10:42 am
Best thing i ever bought, saved a fortune in time and money,Lost count of the stuff i've made. Bike would still be just a pile of bits without it. Here's a pic of my Z1R. Exhaust is cut'n'shut from donor systems and routed around filter housing. Am now looking for more pipe for the drouin.
