Noise
Kari
Noise
#1 PostAuthor: Kari » Thu Apr 02, 2009 5:05 pm
I have some kind of small noise in my engine. I will believe it's coming from alternator case. Is it possibly the stator touch the dynamo?
#2 PostAuthor: Pigford » Thu Apr 02, 2009 6:40 pm
Kari.... most likely the rotor is working loose :!:
Get the casing off & check :??
Kari
#3 PostAuthor: Kari » Thu Apr 02, 2009 7:38 pm
I have just rebuild my engine. But how can I see if rotor is working loose? I have only prize on the rotor and not find any play.
#4 PostAuthor: paul doran » Thu Apr 02, 2009 9:09 pm
Kari it might pay to check the rotor
because if it does come adrift it will wreck your engine
#5 PostAuthor: zed1015 » Thu Apr 02, 2009 9:29 pm
Check that the three cap head screws that bolt the starter clutch roller housing to the back of the rotor are tight.
Users browsing this forum: No registered users and 112 guests
