Z1A resto
- DogsbolloxofZ1B
The bike looks like it is coming up quite well. I have never liked powdercoat but that doesn't look to bad.
At the risk of incurring more abuse from angry people I have to say those instruments look bloody awful. From previous glowing comments by members about the rebuilds done by Mr. Rivett I did expect something closer to an original looking finish.
Okay, fire away...
Okay, fire away...
Dxyselia rlues, oaky.
http://www2.b3ta.com/youcantspell/
RGH wrote:looks like she'll come up tops, what process and paint did you use on calipers and m/cylinder? thanks Hench
Hi Hench,
I used various wire wheel's to remove old paint etc and cleaned them off with acetone, then warmed up calliper/master cyld and paint can's before spraying.
The paint i used was "plasti-kote" project paint primer super and satin super.
I dont know how hard wearing it will be but it gave a good finish
z900 a4 , zx9r
gbh wrote:The bike looks like it is coming up quite well. I have never liked powdercoat but that doesn't look to bad.
Okay, fire away...
The powder coating is ok but i still wish i'd painted it.
As far as the clock's i can't comment on the finish,this being my first rebuild i'v never had first hand experience with original bits,all i have done is look at books
z900 a4 , zx9r
Ginger Bear wrote:That's looking really good Ludders. May I suggest that you use some Dot 5.1 brake fluid, rather than Dot 4, as the 5.1 doesn't have the paint stripping qualities that Dot 4 does, and should keep those calipers,master cylinder looking good.
Thank's for the tip.
This is what i used:
and the paint has'nt fallen off
YET
z900 a4 , zx9r
Mick Hayward
