Oil Pressure gauge.
bigmac103
#16 PostAuthor: bigmac103 » Sat Aug 22, 2009 1:01 pm
Put me down for one!
Lost in the desert somewhere
GUYZED
#17 PostAuthor: GUYZED » Sat Aug 22, 2009 3:09 pm
I'll have one :D
#449
Z1000A2 Z650B1
noelmcguinnessz900
oil pressure gauge
#18 PostAuthor: noelmcguinnessz900 » Sun Aug 23, 2009 10:34 am
put me down for 2 cheers noel
Big Fluff
#19 PostAuthor: Big Fluff » Sun Aug 23, 2009 10:44 am
Hey we're doing well guys.... 11 up to now :D
I haven't a clue about 'import duty', or if there will actually be any, but I'll confirm what I can with the suppliers.
If we can get up to 20 then I'll place the order and will have to sell the extra 5 on myself to recuperate the cost.
I will however require monies up front, either by cheque or paypal.
I consider myself to be most trustworthy and will make sure we get the best deal possible.
Regards, Will :rap
martinz1b
#20 PostAuthor: martinz1b » Sun Aug 23, 2009 10:49 am
Put me down for one as well please.
Mart
hillbilly
#21 PostAuthor: hillbilly » Sun Aug 23, 2009 11:07 am
ile have one :lol: let me know when you need payment.
lta01
#22 PostAuthor: lta01 » Sun Aug 23, 2009 3:01 pm
Will, I'll have one please.
Some US suppliers describe the goods as commercial or marketing samples , which means they don't attract any duty usuallly.
He who dies with the most toys wins .
BShaw
#23 PostAuthor: BShaw » Sun Aug 23, 2009 11:07 pm
No problem, as soon as you want it shout, I am on holiday from 8th till 18th sep, but am sure we will know by then. will order include angles ?
Baza
Baza
Big Fluff
#24 PostAuthor: Big Fluff » Mon Aug 24, 2009 9:04 am
BShaw wrote:Will the order include the angles ?
Baza
Baz - They don't include the 90° elbow, nor can they supply one.
However, as soon as I get a gauge, I could source the required parts including drill & cutting tap. We could then take it in turns to do the necessary mod, then post on to each other member who bought a gauge so they can finish the job.
Will.
BShaw
#25 PostAuthor: BShaw » Mon Aug 24, 2009 10:29 am
Will, Sounds good to me, whatever I can do.
Thanks for sorting all this out. I just hope we get enough takers.
Regards
Baza
Baza
Gus
#26 PostAuthor: Gus » Mon Aug 24, 2009 10:31 am
"Set the GRINDER on it"
#27 PostAuthor: zed1015 » Mon Aug 24, 2009 5:28 pm
The 63mm one off evilbay is too big, not glycerine filled and cheap and nasty but the speedflowshop one looks good. At 1-5/8ths (40mm) its spot on and looks good quality. Will still need a 90 deg angled fitting though.
Big Fluff
#28 PostAuthor: Big Fluff » Tue Aug 25, 2009 6:15 am
Update from Marshall in the states.....
There will be VAT on top and maybe import duty too. :??
The one Gus found by Speedflow is the same exact gauge as the Marshall one, just different text. The needle shape, screws, everything is identical. Price is £23.32. Contact Speedflow on 0870 225 0097.
To be honest, I think this would be a better move than to order a job lot from the states. After the VAT has been added, and possible inport duty, there won't be anything between them price wise. Also, If I order from the states, I may be left with gauges I can't sell if we don't get enough takers.
Here's the Marshall one again....
and here's the Speedflow one.
See, exactly the same.
As with both, you'll still need a 90 degree fitting. There's a hydraulics company just around the corner from where I work, I know the bloke who runs it so could get a deal on the fittings.
I'm going to order one for myself and I'll let you all know of the fitting/tap required etc, unless Zed1025 beats me to it :wink:
Hope you all understand, Regards, Will.
martinz1b
#29 PostAuthor: martinz1b » Tue Aug 25, 2009 6:36 am
Yeah, no problem. It seems a lot of hassle for little gain, I will probably buy one from speedflow. I will watch out for your update about the bends.
Mart
BShaw
#30 PostAuthor: BShaw » Tue Aug 25, 2009 8:09 am
Yep you'r probably right Will, but thank you for chasing it up and offering to put the dosh up and sort things out etc, Soooo much hassle from the states.(what if one or two didn't work ?)
Let me know about the 90.
Cheers mate
Baza
