I will be getting my modified head back soon and have a query with the ignition side of things. I will be fitting green Dyna coils, which match the ones already fitted.
The query is how are they wired is it just a matter of splitting each wire to the coils and connecting them in the same order as if the head had single plugs.
Cheers Rob
8 plug head ignition query
Don't wire in parallel, It won't work. You will get a spark at only one coil or the other which ever offers a path of the least resistance. Also when fitting the HT leads don't put both leads from one coil just to one cylinders plugs. Say cyl's 1 and 4 should have one HT lead each from their pair of coils. That way if a coil fails you don't totally lose spark to either cylinder.
