Cam covers
- harrythemagnum
Cam covers
Will be looking for an engine soon for a MkII project, if I cant find a proper MkII motor can I make an older engine look like one by changing the covers?
What a wonderful philosophy you have,
YES! Except the alt cover as the earlier engine has a smaller alt taper and the associated cover is smooth apart from the DOHC logo.
The later mk2 has a larger taper and different design alt with a cover that has ribs/finning.
Fitting a mk2/st crank would solve that problem and allow the correct alt and cover to be fitted.
- harrythemagnum
- Ginger Bear
