Mirrors
Wayne1960
Mirrors
#1 PostAuthor: Wayne1960 » Sun Sep 18, 2016 8:15 pm
Is there a way of telling if I have original mirrors and can you stil get originals?
Bike now finished what a joy!
#2 PostAuthor: z1bman » Sun Sep 18, 2016 8:52 pm
originals still available at cradley but £52 each
tlc
#3 PostAuthor: tlc » Mon Sep 19, 2016 6:15 am
Pattern mirrors blur after 30mph.
Genuine ones do it after 60.
Chrisu bought some pattern ones and put in some anti vibration material which improved them considerably.
#4 PostAuthor: Garry.L » Mon Sep 19, 2016 7:24 am
As above. If you can see anything behind you much past 20mph there's a chance they're genuine.
I used some silicon behind the glass on an old pattern set and it improved them no-end.
#5 PostAuthor: chrisu » Mon Sep 19, 2016 10:28 am
tlc wrote:Pattern mirrors blur after 30mph.
Not quitecorrect chris. I bought a set of short stem mirrors off ebay from a company called yuniparts. These had metal/rubber mountings which damped vibration. I just swapped the stems for std Z length ones.
Sadly looks like they don't do them any more. I guess you could contact them to see if they do have any.
Wayne1960
#6 PostAuthor: Wayne1960 » Mon Sep 19, 2016 2:47 pm
So I had the stems re finished but the mirror bodies look cheap or should they?
Are there no typical Kawasaki numbers or marks to look out for?
Wayne1960
#7 PostAuthor: Wayne1960 » Mon Sep 19, 2016 3:39 pm
Can you get replacement glass?
PAULJAC47
#8 PostAuthor: PAULJAC47 » Mon Sep 19, 2016 3:44 pm
If you look on ebay find some pattern type mirrors but ensure the stem goes into a threaded portion on the mirror not into a brass bush which is pressed into the cheap repro ones ,then just swap the complter mirror inserts,need a bit of fiddling but i have done this with some success and no vibes!
Kev1R
#9 PostAuthor: Kev1R » Mon Sep 19, 2016 6:19 pm
From a previous thread I believe KeithZ1r recommends these which are similar to originals and come in long stem or shorter stem (for Z1R) and apparently do not vibrate.
http://www.ebay.co.uk/itm/221245531641? ... EBIDX%3AIT
From experience I would avoid the 'Emgo' make of mirrors as they simply do not work.
Kevin
010
PAULJAC47
#10 PostAuthor: PAULJAC47 » Mon Sep 19, 2016 6:24 pm
Yep there the ones!
Wayne1960
#11 PostAuthor: Wayne1960 » Mon Sep 19, 2016 6:50 pm
ok taken the mirror body off the stem and it has the brass inserts!!!!!
so there not original right?
Wayne1960
#12 PostAuthor: Wayne1960 » Mon Sep 19, 2016 7:14 pm
stripped mirror and it says KDC 77-05-16
wheelysteve
#13 PostAuthor: wheelysteve » Mon Sep 19, 2016 7:22 pm
I've got those on long stems also. They are virtually identical to the original Kawasaki items, only difference is a slightly rougher finish on the back.
I put foam in the back of mine just to make sure and they are rock steady at any legal speed Wink
I think the right hand mirror is a new genuine Kawasaki item, the other is the Yuniworld job
_________________
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Wayne1960
#14 PostAuthor: Wayne1960 » Mon Sep 19, 2016 7:35 pm
Ah now we are talking so mine are actually genuine cheap crap! i thought so as they are all plastic.
i need to get myself the genuine article
#15 PostAuthor: chrisu » Mon Sep 19, 2016 8:22 pm
Kev1R wrote:From a previous thread I believe KeithZ1r recommends these which are similar to originals and come in long stem or shorter stem (for Z1R) and apparently do not vibrate.
Kevin
That's them. Same company
