Z1000 a1 Valve stem seals head on
tad
#1 PostAuthor: tad » Wed Feb 06, 2019 4:50 pm
Guys
anyone ever changed the seals head on ? I am talking about as in car engines etc with a length of rope in the bore ?
is it possible on a Z ?
Re: Z1000 a1 Valve stem seals head on
#2 PostAuthor: Pigford » Wed Feb 06, 2019 5:22 pm
Can be done as you say - but fiddly, so probably better to bite the bullet & give her a good decoke & check whilst you're at it.
#3 PostAuthor: warren3200gt » Wed Feb 06, 2019 5:25 pm
How would you compess the valve spring to release the colletts?
#4 PostAuthor: zed1015 » Wed Feb 06, 2019 5:31 pm
warren3200gt wrote:How would you compess the valve spring to release the colletts?
You use a compressor that bolts to the top of the head.
Valve can also be kept from dropping by using compressed air instead of rope.
#5 PostAuthor: warren3200gt » Wed Feb 06, 2019 6:19 pm
Hmm, not seen one of those, always used the G clampy shaped ones. So head off.
#6 PostAuthor: zed1015 » Wed Feb 06, 2019 7:50 pm
This is the type of thing.
Popular in the car trade.
https://www.lasertools.co.uk/product/5495
#7 PostAuthor: warren3200gt » Wed Feb 06, 2019 8:17 pm
So your supposed to bolt it to the cam caps or the cam cover ?
