In the parts stash so far for the Z1R there's the spare rebuilt and balanced Rajay turbo from the Orient express drag bike, a Wastegate ( but no exhaust to join it all together as yet ), ATP plenum, Super B carb that I first had on the Drouin, GPZ1100 Unitrack cams, Ape 32t slotted cam sprockets ,MTC lockup clutch, Barnett extra plate clutch pack, Titanium valve spring retainers, HD cylinder studs, bronze guides and the remains of a Bill Hahn Boost retard distributer ignition that's missing the cover, GM hei module, belt, crank pulley and coil.
- PICT0076.JPG (292.99 KiB) Viewed 362629 times
And here a fresh welded MK2 crank (by Roger Upperton), assorted APE nuts, case studs, top idler bracket, needle clutch pusher etc, a Deep sump with Turbomaxx billet 40% extra flow oil pump and a freshly bored 1075cc block with 10.25 comp Wiseco pistons.
The head will be either a J or GPZ1100 Unitrack who's larger 40cc combustion chambers will drop the comp down to a turbo friendly 8 to 1.
- PICT0080.JPG (310.83 KiB) Viewed 362629 times
For the "B" based bike which will have "A" bodywork there's another fresh 1075cc block with 12 to 1 comp Wiseco's ( again dropping to around 10 -1 with a 'J' head ), a set of fast road Kent cams 'w' slotted sprockets , Ti retainers, HD valve springs, my own billet idler wheels, HD cam chain etc and two pairs of 1.5 ohm dyna coils and Dyna S' ignition for the 8 plug head.
- PICT0082.JPG (286.52 KiB) Viewed 362629 times
Also got a very nice welded 900 crank.
- PICT0083.JPG (225.1 KiB) Viewed 362629 times
And the J head i twin plugged that was originally on the Drouin.
- PICT0084.JPG (251.96 KiB) Viewed 362629 times
