Recommendations
wheelysteve
Recommendations
#1 PostAuthor: wheelysteve » Wed Feb 19, 2020 1:30 pm
Can anyone recommend a good quality engine assembly lube and a decent sealant for the crankcase halves ?
Cheers, Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Coose
Re: Recommendations
#2 PostAuthor: Coose » Wed Feb 19, 2020 2:56 pm
As advised by Al, Loctite 5980 is good but always buy it from a shop as it has a Use By date and will not go off if it's exceeded - the date is on the tube, not the box. You can get it from Halfords.
Re: Recommendations
#3 PostAuthor: zed1015 » Wed Feb 19, 2020 3:39 pm
I use these.
The Vtech is good for all the case joints, Cam end plugs , Alternator grommet etc.
https://www.ebay.co.uk/itm/VT-157-Quali ... zyLv1Sv3C1
And the Graphogen for the cam shells, buckets, Piston skirts etc etc.
https://www.ebay.co.uk/itm/Engine-Build ... SwleNcph0g
wheelysteve
Re: Recommendations
#4 PostAuthor: wheelysteve » Fri Feb 21, 2020 9:22 am
Thanks lads.
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
LTD Project
Re: Recommendations
#5 PostAuthor: LTD Project » Fri Feb 21, 2020 9:38 am
For engine assembly I use 50/50 molybdenum grease and engine oil.
Otherwise Blue Hylomar or Loctite for joint faces.
Good Luck!
rickm
Re: Recommendations
#6 PostAuthor: rickm » Fri Feb 21, 2020 10:12 am
Blue hylomar is good stuff :up
H2B GPZ900R
