Z650 (z1000 carbs)
Wavydave
Z650 (z1000 carbs)
#1 PostAuthor: Wavydave » Sun Mar 29, 2020 10:07 am
Hi all ,
I'm looking to fit some non pumped z1000 carbs to my z650
Is it worth doing? A straight forward job and any ideas on jetting
If fitted...
Cheers Dave
Re: Z650 (z1000 carbs)
#2 PostAuthor: zed1015 » Sun Mar 29, 2020 11:35 am
It's a common mod and will wake up the motor a bit.
You need to use the 900/1000 inlet rubbers too and slot the mounting holes slightly to get them to fit as the holes are fractionally wider apart than the 650.
Start with the stock 1000 jetting and work down on the mains.
Swirl
#3 PostAuthor: Swirl » Sun Mar 29, 2020 6:49 pm
Sure Padders has a set for sale
