Valve Guide for Z1900
KwakaRascal
#1 PostAuthor: KwakaRascal » Fri Feb 05, 2021 12:14 pm
Hi,
Looking for an Inlet & Exhaust valve guide.
They can be new or old ( ideally Bronze type).
Reason being, am going to have replacement oversize ones made but need a pattern part to work to.
The ones currently in the head are nothing like the originals.
Can anyone help me with this?
Russ.
07733327245
8 Valve Mark
Re: Valve Guide for Z1900
#2 PostAuthor: 8 Valve Mark » Fri Feb 05, 2021 12:19 pm
hi russ, it's probably more economical to replace the lot rather than source two, buy the metal and turn a new set out. these are available in the UK...https://www.ebay.co.uk/itm/303584659196 good luck..
#3 PostAuthor: zed1015 » Fri Feb 05, 2021 12:25 pm
You can buy oversize aluminium bronze guides for these from APE.
All the z650 - 900 to gpz1100 aircooled and Suzuki GS1000 are the same fitting.
They have a machined shoulder rather than a circlip and sit lower in the head for high lift cam clearance so maybe this is what you currently have fitted.
They are around £13 each which may be cheaper than having one offs made.
Various OD oversizes are available.
Here's a link to Nicks UK shop who can supply them.
https://www.suzukiperformancespares.co. ... s-ape/885/
KwakaRascal
#4 PostAuthor: KwakaRascal » Fri Feb 05, 2021 12:53 pm
Hi 8 valve Mark,
Yeah your right, i will replace all eight.
Just need a pattern to work to.
Also, chances are I’ll have to have made oversize to fit into head.
KwakaRascal
#5 PostAuthor: KwakaRascal » Fri Feb 05, 2021 12:56 pm
Hi Z1015,
Thanks for the lead, I’ll give them a call.
:up
