Z1000 MK11/ST Frame
poontang19
- new poster
Z1000 MK11/ST Frame
Can any one tell if the Z1000 MK11 and ST Frames are different
Re: Z1000 MK11/ST Frame
Yes! The most noticeable difference is that the ST shaft drive frame is wider at the S/A pivot and has cast steel pivot
mounts .
MK2 frame is basically the same as a Z1R.
mounts .
The frames are very different, it is impossible to swap MK2 and ST bodywork and seat without cutting and welding.. and of course the already mentioned width on the left side where the shaft middle gear resides..
Hi poontang19
if you want to know more about the Z1000ST and the MK2, have a look here:
viewtopic.php?f=46&t=44425
You can see the topic if you're a PUM.
