My Z Project
You can keep this set-up but fit a blanking disc under the pressure switch outlet to the main gallery (or plug the switch body)
All the oil would then be diverted through the cooler, that way you get to keep the oil light without having to shell out for expensive oil cooler fittings .
I use the blanked off port in the switch body for the cooler feed as for the pressure switch to work correctly it should be within the flow of the oil.
Anuar Kamaruddin
- Regular Poster
My Z1 project
Thanks Zed1015 for the advice,will try your suggestion.
AKM
AKM
Anuar Kamaruddin
- Regular Poster
My Project
Paintwork for the Z1R is ready less the fairing and the seat strips.
- octanejunkie
- Regular Poster
Anuar Kamaruddin
- Regular Poster
My Z project
Anuar Kamaruddin
- Regular Poster
http://s1140.beta.photobucket.com/user/ ... sort=3&o=0 the Z1R is on the road less fairing n seat rails
zmaxmotorsports
- Regular Poster
Did you have to modify anything to make the z1r bodywork fit?
Ive only been wanting a blue 78z1r since about 1979!
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
Anuar Kamaruddin
- Regular Poster
Z1R conversion
Yes,the tail end frame need to be mod to fix tail unit,the frame where the seat is attached need mods,the bottom mounting hole for the side covers to be relocated and the hardest would be the fairing brackets:)
- z1000puddin
Anuar Kamaruddin
- Regular Poster
Anuar Kamaruddin
- Regular Poster
Z1R
Thanks Holeshot, just came back burning the Expressway,need a lot to brush-up my skills after 18 years of laying-off but the thrill is always there with the Z
.Cannot push her to the limit yet coz the standard brake m/cylinder cannot activate the twin Lockheed front calipers effectively.My new Lockheed front m/ cylinder is being assembled,tested,quality control at AP Racing,should arrived by end of February.
Users browsing this forum: No registered users and 180 guests
