My Z Project
#46 PostAuthor: zed1015 » Fri Oct 26, 2012 9:41 am
You can keep this set-up but fit a blanking disc under the pressure switch outlet to the main gallery (or plug the switch body)
All the oil would then be diverted through the cooler, that way you get to keep the oil light without having to shell out for expensive oil cooler fittings .
I use the blanked off port in the switch body for the cooler feed as for the pressure switch to work correctly it should be within the flow of the oil.
Anuar Kamaruddin
My Z1 project
#47 PostAuthor: Anuar Kamaruddin » Sat Oct 27, 2012 5:04 pm
Thanks Zed1015 for the advice,will try your suggestion.
AKM
Anuar Kamaruddin
My Project
#48 PostAuthor: Anuar Kamaruddin » Fri Dec 07, 2012 12:31 pm
Paintwork for the Z1R is ready less the fairing and the seat strips.Image
octanejunkie
#49 PostAuthor: octanejunkie » Tue Dec 11, 2012 9:33 am
One of the most exciting bits of a project is fitting the freshly painted bits.. :brav
"People are more opposed to fur than they are leather because its safer to harass rich women than it is motorcycle gangs"
Anuar Kamaruddin
My Z project
#50 PostAuthor: Anuar Kamaruddin » Tue Dec 11, 2012 11:54 am
Anuar Kamaruddin
#51 PostAuthor: Anuar Kamaruddin » Thu Jan 31, 2013 5:00 am
http://s1140.beta.photobucket.com/user/ ... sort=3&o=0 the Z1R is on the road less fairing n seat rails
zmaxmotorsports
#52 PostAuthor: zmaxmotorsports » Thu Jan 31, 2013 6:38 am
Did you have to modify anything to make the z1r bodywork fit?
Ive only been wanting a blue 78z1r since about 1979! :lol:
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
Anuar Kamaruddin
Z1R conversion
#53 PostAuthor: Anuar Kamaruddin » Thu Jan 31, 2013 9:56 am
Yes,the tail end frame need to be mod to fix tail unit,the frame where the seat is attached need mods,the bottom mounting hole for the side covers to be relocated and the hardest would be the fairing brackets:)
#54 PostAuthor: Pigford » Thu Jan 31, 2013 3:17 pm
Nice
sanderz
#55 PostAuthor: sanderz » Thu Jan 31, 2013 7:15 pm
Very, very nice that Anuar :up
Crackin' job!!
Wots up DOHC
z1000puddin
#56 PostAuthor: z1000puddin » Thu Jan 31, 2013 8:21 pm
Very Very Nice, I like this a lot, Not overly done & very subtle :wink: :drool
Zed til Dead
Anuar Kamaruddin
#57 PostAuthor: Anuar Kamaruddin » Fri Feb 01, 2013 3:05 am
Thanks mate for the kind comments :)
Holeshot
#58 PostAuthor: Holeshot » Fri Feb 01, 2013 9:19 am
Very, veeeeery nice indeed!
Perfectly beefed up.
Now get out and ride it!!
:D
Anuar Kamaruddin
Z1R
#59 PostAuthor: Anuar Kamaruddin » Fri Feb 01, 2013 12:30 pm
Thanks Holeshot, just came back burning the Expressway,need a lot to brush-up my skills after 18 years of laying-off but the thrill is always there with the Z :D.Cannot push her to the limit yet coz the standard brake m/cylinder cannot activate the twin Lockheed front calipers effectively.My new Lockheed front m/ cylinder is being assembled,tested,quality control at AP Racing,should arrived by end of February.
ruffle
#60 PostAuthor: ruffle » Fri Feb 01, 2013 1:17 pm
That looks really good.
Are you going to fit the side rails and some Z1015R side panel badges?
Users browsing this forum: No registered users and 174 guests
