Ignition Leads
Ignition Leads
Hi,
My 1000J could do with some new ignition leads.
At the moment, it has new standard Kawasaki coils in good condition, with some yellow silicon leads which have seen better days.
I’ve been told that the Dyna Performance leads will not work with standard coils?
Can anyone recommend a good-looking aftermarket replacement set of leads, without having to buy new coils as well?
Thanks,
Rick
Thanks,
Rick
H2B GPZ900R
Re: Ignition Leads
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Re: Ignition Leads
Thanks for that, but I've been told (by a certain specialist company who sell the coils and lead sets) that the Dyna leads will not work with standard coils.
Is this just bull ?
Is this just bull ?
H2B GPZ900R
Re: Ignition Leads
Can anyone confirm whether the standard coils need 7mm or 8mm leads?
The ones fitted at the moment that I'm looking to replace are 7mm.
H2B GPZ900R
Julian_Boolean
Re: Ignition Leads
Dyna leads don't fit in standard coils, I can probably find a short length of Dyna lead and send it to you if you want to try it.
Re: Ignition Leads
rickm wrote:Thanks for that, but I've been told (by a certain specialist company who sell the coils and lead sets) that the Dyna leads will not work with standard coils.
Is this just bull ?
From an electrical point of view that is 1st class bullshit.
But they may mean that the leads diameter is too fat to fit the stock coil.
Julian_Boolean
Re: Ignition Leads
zed1015 wrote:rickm wrote:Thanks for that, but I've been told (by a certain specialist company who sell the coils and lead sets) that the Dyna leads will not work with standard coils.
Is this just bull ?
That is exactly what the problem is
Julian_Boolean
Re: Ignition Leads
BTW Dyna leads look very similar to the ones I put on Ford Puma a few years ago that came from Motorspares and cost about £20 for the set.
Julian_Boolean
Re: Ignition Leads
Yes, the cheap stuff isn't really flexible enough though, it'll work but won't turn tight enough to look nice.
Re: Ignition Leads
Guyzz
May be wrong but don't the standard coils have built in leads hence can't be removed for replacement ????
Phil
Phil
International Rep
International Rep
Re: Ignition Leads
The ones on the 1000J have a screw cap, and the lead just pushes onto a spike and is held on by the cap.
H2B GPZ900R
Julian_Boolean
Re: Ignition Leads
Supposed to be held on by the cap would be more accurate, though new coils are probably better than the 35 year old ones I had.
Re: Ignition Leads
you just need summat like this
https://www.autoelectricsupplies.co.uk/ ... tegory/115
there are other types available, just leave a tail on the moulded leads long enough to fit one of them to each
this statement :_ " Dyna leads will not work with standard coils."
comes under the heading of not actually lying just not telling all the truth
Keith
mistaken.
mistaken.
