Ignition Leads
rickm
Ignition Leads
#1 PostAuthor: rickm » Fri Nov 10, 2017 2:26 pm
Hi,
My 1000J could do with some new ignition leads.
At the moment, it has new standard Kawasaki coils in good condition, with some yellow silicon leads which have seen better days.
I’ve been told that the Dyna Performance leads will not work with standard coils?
Can anyone recommend a good-looking aftermarket replacement set of leads, without having to buy new coils as well?
Thanks,
Rick
Z1000J ELR US style, S3 400 triple
KeithZ1R
Re: Ignition Leads
#2 PostAuthor: KeithZ1R » Fri Nov 10, 2017 2:32 pm
just to start the ball rolling
http://www.ebay.ie/itm/Kawasaki-Z1000J- ... Swd0BV3Luc
good luck :)
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
rickm
Re: Ignition Leads
#3 PostAuthor: rickm » Fri Nov 10, 2017 2:49 pm
Thanks for that, but I've been told (by a certain specialist company who sell the coils and lead sets) that the Dyna leads will not work with standard coils.
Is this just bull ?
rickm
Re: Ignition Leads
#4 PostAuthor: rickm » Fri Nov 10, 2017 4:22 pm
Can anyone confirm whether the standard coils need 7mm or 8mm leads?
The ones fitted at the moment that I'm looking to replace are 7mm.
Julian_Boolean
Re: Ignition Leads
#5 PostAuthor: Julian_Boolean » Fri Nov 10, 2017 4:41 pm
Dyna leads don't fit in standard coils, I can probably find a short length of Dyna lead and send it to you if you want to try it.
Re: Ignition Leads
#6 PostAuthor: zed1015 » Fri Nov 10, 2017 4:42 pm
rickm wrote:Thanks for that, but I've been told (by a certain specialist company who sell the coils and lead sets) that the Dyna leads will not work with standard coils.
Is this just bull ?
From an electrical point of view that is 1st class bullshit.
But they may mean that the leads diameter is too fat to fit the stock coil.
Julian_Boolean
Re: Ignition Leads
#7 PostAuthor: Julian_Boolean » Fri Nov 10, 2017 4:50 pm
Is this just bull ?
That is exactly what the problem is
Julian_Boolean
Re: Ignition Leads
#8 PostAuthor: Julian_Boolean » Fri Nov 10, 2017 4:55 pm
BTW Dyna leads look very similar to the ones I put on Ford Puma a few years ago that came from Motorspares and cost about £20 for the set.
rickm
Re: Ignition Leads
#9 PostAuthor: rickm » Fri Nov 10, 2017 4:57 pm
So I just need 7mm replacement leads then?
Julian_Boolean
Re: Ignition Leads
#10 PostAuthor: Julian_Boolean » Fri Nov 10, 2017 5:03 pm
Yes, the cheap stuff isn't really flexible enough though, it'll work but won't turn tight enough to look nice.
Hobbo
International Rep
Re: Ignition Leads
#11 PostAuthor: Hobbo » Fri Nov 10, 2017 5:08 pm
Guyzz
May be wrong but don't the standard coils have built in leads hence can't be removed for replacement ????
Phil
International Rep
rickm
Re: Ignition Leads
#12 PostAuthor: rickm » Fri Nov 10, 2017 5:12 pm
The ones on the 1000J have a screw cap, and the lead just pushes onto a spike and is held on by the cap.
Julian_Boolean
Re: Ignition Leads
#13 PostAuthor: Julian_Boolean » Fri Nov 10, 2017 9:20 pm
Supposed to be held on by the cap would be more accurate, though new coils are probably better than the 35 year old ones I had.
KeithZ1R
Re: Ignition Leads
#14 PostAuthor: KeithZ1R » Sat Nov 11, 2017 12:05 pm
you just need summat like this
https://www.autoelectricsupplies.co.uk/ ... tegory/115
there are other types available, just leave a tail on the moulded leads long enough to fit one of them to each
this statement :_ " Dyna leads will not work with standard coils."
comes under the heading of not actually lying just not telling all the truth :roll:
Keith
:bop :gom
mistaken.
Users browsing this forum: No registered users and 5 guests
