Z1000J carb on Z1R
Z1000J carb on Z1R
On a bike Im Breaking I've stumbled across a set of z1000j carbs, would these be good on my 1045cc high compression engine, 71mm forged pistons Andrew's cams etc, I've asked a couple of times and was told by a couple of members to go with z1000 28mm carbs which I had but sold when I needed some quick cash, I had a couple of sets of Vm29 flatslides which ive sold on as 29mm smoothbores were mentioned, ive now stumbled on these which I already have, I think they are bst34's, so thoughts on the the 3 different sets of carbs, 28mm Z1000, 29mm smoothbores, z1000j carbs, comparisons if you can, value/performance cheers Swirl
Re: Z1000J carb on Z1R
1000J carbs as a last resort.
VM28's will work well with the engine spec you have.
My 29mm Smoothbores work wonderfully on my J that has a flowed and skimmed head (0.5mm), B2 cams, 1mm oversize and an old Kerker race pipe.
zed1015 wrote:1000J carbs as a last resort.
Another set to the sale room then
- 8 Valve Mark
+1 for vm28 option, bs34's should be ok too for functionality but they wont look like they belong there paul, you probably regret flogging the 29's eh?doh! I've got a spare set of vm28 pumpers i could live without... m
Got someone on first refusal on the 34's so I'll see how we go, 28mm the way to go
Users browsing this forum: Google [Bot] and 123 guests
