GPz11 - which black?
moizeau
#1 PostAuthor: moizeau » Wed Apr 23, 2025 6:06 pm
Trying to sort some bits out on the A1 and would like confirmation regarding bits that are painted gloss black. So far I've got ( I think)
Calipers
Master cylinders
Passenger grab handles x3
Outer engine cases
Headlight surround
Airbox side covers
I presume the forks but they're already Tough Black Satin. Can I just final coat in gloss?
I'm thinking of using Tough Black Gloss
Any confirmation or enlightenment gratefully received.
Edit, if it makes a difference, this is a white one
johnA
Re: GPz11 - which black?
#2 PostAuthor: johnA » Wed Apr 23, 2025 6:48 pm
Hello Pete the master cylinder is satin the rear grab rail is gloss the side grab rails are satin outer engine casings are gloss as are the airbox covers. on mine the headlight surround is plastic as far as i know i can check tomorrow for you. and the calipers look like dark grey metallic to me unless they have faded over the years and the forks are gloss.
moizeau
#3 PostAuthor: moizeau » Thu Apr 24, 2025 8:04 am
Thanks John. The headlamp surround I'm referring to is the bit that screws to the glass, not the bowl. Mine is metal....and a bit rusty. Cheers for the ther info.
#4 PostAuthor: deka » Thu Apr 24, 2025 9:26 am
calipers are a verylight metalic grey green mixture. if memory servers it is a Vauxhall colour its hard to define zoom in on pic to view
johnA
#5 PostAuthor: johnA » Thu Apr 24, 2025 12:07 pm
Hello Pete the headlight surround is satin
moizeau
#6 PostAuthor: moizeau » Thu Apr 24, 2025 3:32 pm
Thanks Deka for the info and also for the photo.Cheers John.
stusco
#7 PostAuthor: stusco » Sat May 03, 2025 1:16 pm
As we are talking colours what colour is the red in the gpz on the side casings?
johnA
#8 PostAuthor: johnA » Sat May 03, 2025 8:23 pm
The emblems on the engine casings look like the firecracker red to me the same as the body work they are still available from zpower
stusco
#9 PostAuthor: stusco » Sun May 04, 2025 1:59 pm
How do they come off ? Mine look permanent. And sixty quid each is a bit steep
johnA
#10 PostAuthor: johnA » Sun May 04, 2025 9:09 pm
It looks like a double sided sticky pad that cover the whole diameter of the badge to hold them on i can send you a couple of photo's if you like.
stusco
#11 PostAuthor: stusco » Mon May 05, 2025 10:15 am
Go on that would be great
moizeau
#12 PostAuthor: moizeau » Mon May 05, 2025 3:39 pm
I've seen the stickers and presumed they must have been for certain variants as mine really looks not like a sticker. If it is I'm guessing they are ally and reasonably thick as the recess is 0.25mm deep. I'm glad this has been mentioned because I was about to blast it back to bare metal.
stusco
#13 PostAuthor: stusco » Tue May 06, 2025 6:27 pm
I did blast mine ,ive buffed it up i think ill just repaint it as i cant see it coming off without damaging the case
moizeau
#14 PostAuthor: moizeau » Thu May 29, 2025 4:49 pm
And the footpeg hangers? On Deka's they look gloss or maybe that's the light?
Any other gloss bits?
moizeau
#15 PostAuthor: moizeau » Mon Jul 21, 2025 5:30 pm
Another question.
I read an article saying the frame is gloss?
Also, is the cam cover gloss?
