DROUIN Supercharged Z1000A ..
ted1r
post
#181 PostAuthor: ted1r » Sat May 23, 2009 3:06 pm
Brill, this man is amazing at what he does and its not far from me too,Zed any chance I can pop and have a butchers in the flesh mate?
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
phil churchett
#182 PostAuthor: phil churchett » Sat May 23, 2009 7:57 pm
Superb, i always take the time to read anything posted on this thread.
The only thing that p****s me off, is you make everything look so easy.
Be nice to see the finished article on the club stand at Stafford in October.
How about it?
#183 PostAuthor: zed1015 » Sun May 24, 2009 3:36 pm
Would be honoured to have it on the club stand. Will have to see if i can get it finished by then :?: . I'm now actively seeking someone to do the paint who will maybe do a bit of bartering :wink:. Anyone interested :?:
Re: post
#184 PostAuthor: zed1015 » Sun May 24, 2009 3:43 pm
ted1r wrote:Brill, this man is amazing at what he does and its not far from me too,Zed any chance I can pop and have a butchers in the flesh mate?
Ted
If i make it to the yorks rally you can take a detour back to mine on the way home.
Padders
#185 PostAuthor: Padders » Sun May 24, 2009 4:03 pm
Have you had a word with Hutch ref the paintwork.
#186 PostAuthor: zed1015 » Sun May 24, 2009 4:06 pm
PADDERS wrote:Have you had a word with Hutch ref the paintwork.
Who :?: , Where :?:
Padders
#187 PostAuthor: Padders » Sun May 24, 2009 4:29 pm
Mark Hutchinson 01977 678417
paints many of the bikes in the club excellent job.
ted1r
post
#188 PostAuthor: ted1r » Sun May 24, 2009 9:24 pm
Deal mate.
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
#189 PostAuthor: zed1015 » Sun Jun 21, 2009 5:10 pm
Its been a while since i've done anything worthy of note and there's a miriad of niggly bits you can't see that need sorting before its finally finished. However i have at last decided on a paint scheme and have been preparing the body work for the event. In the last posts i had modded the tank to take the race filler but wasn't happy where the hole intersected with one of the old spot welds towards the front of the tank which held the original cap mount. The metal in this area is also very thin due to corrosion and slightly distorted and although it does straighten out and seal when the cap is bolted on i have visions of the paint cracking so decided to create a solid flange that will take the cap and not flex when bolted up.
I machined up this 3mm steel ring
Which was then bolted flat to the tank
[b] Then pre heated the tank with an hot air stripper to reduce the heat differential and limit the risk of distortion when the ring was brazed in place
[b]And that i think is it for the bodywork , Just the addition of a breather and i'm ready for the paint which i hope to get away in the next week or two.
Steve R
#190 PostAuthor: Steve R » Sun Jun 21, 2009 5:36 pm
As usual, awesome work mate!!
#191 PostAuthor: zed1015 » Sun Jun 21, 2009 5:38 pm
Another unplanned mod is to the kickstart which clobbered the toe peg of the brake lever. I had already made the footrest hinge up out of the way but obviously things never are that simple. I did toy with the idea of hinging the toe peg as well but decide that was a bit extreme and finally went for the easy option . I've had to heat the lever and bend it out near the pivot then bring the other end back up so it sits at 90deg to the frame as it should when swung out. This does bring the lever quite far out now so to combat any tendancy to twist or bend i've introduced a strengthening plate that as well as beefing up the shaft length ways is also positioned diagonally along the lever to resist twisting. Just got to get this powder coated and that's another item off the to do list.
PICT0195 (1).jpg (137.27 KiB) Viewed 5110 times
bakey
#192 PostAuthor: bakey » Tue Jun 23, 2009 11:43 am
just jaw droppingly awesome :more
if i had an ounce of your ability i would be happy.
always enjoy reading this thread, cannot wait to see it finished.
what a machine this is going to be.
A-MA-ZIN
''Who's motorcycle is this?''
brian 450
#193 PostAuthor: brian 450 » Tue Jun 23, 2009 12:19 pm
Looking really nice mate. What colour is it going to be?
Big Fluff
#194 PostAuthor: Big Fluff » Tue Jun 23, 2009 12:23 pm
It's not just the engineering skills that are highlighted during this project, it's the unique thought of overcoming every problem thrown at him :roll:
Amongst all the other work, the fuel tank filler is bloody excellent. :more
#195 PostAuthor: zed1015 » Tue Jun 23, 2009 12:25 pm
brian 450 wrote:Looking really nice mate. What colour is it going to be?
Pretty sure its gonna be classic zed green 'n' yellow now :?: . basic race stylee with white number boards on the tail but that may change once i get to the painters :wink:
